Graphics detail in Doom
First post, by Syntho
I built a P100 DOS machine with a Diamond Stealth Pro 4mb card in it. It has been so long since I properly played DOS games that I don't remember the experience much. When I load up Doom and switch the graphics detail to High I get a little slower framerate as compared to the Low setting. I guess I'm spoiled in getting 60fps on everything.
To have the detail on High to get that faster, fluid framerate, would I need an even better video card? I was thinking the card I got would do that, but maybe FPS games are a bit more video intensive than I thought.
Reply 1 of 12, by appiah4
Doom runs smooth at High level on anything that is as fast as or faster than a 486 DX4-75MHz, if you have a VLB or PCI video card. The game is capped at 35 FPS so you will never get 60 FPS on that using the default rendering engine.
Reply 2 of 12, by kixs
You probably have PCI card - Diamond Stealth 2000 PRO . Without 2000 it's an ISA card. That would be a bottleneck for P-100 and graphics would be very slow.
Reply 3 of 12, by appiah4
kixs wrote on 2023-01-20, 08:52:
Is there a 4MB ISA Diamond Stealth? I doubt it.
Reply 4 of 12, by Falcosoft
appiah4 wrote on 2023-01-20, 08:49:
... The game is capped at 35MHz so you will never get 60 FPS on that using the default rendering engine.
35MHz would mean a cap of 35000000 FPS. It's rather 35 Hz (half of the refresh rate).
Website, Youtube
VST Midi Driver Midi Mapper
x86 microarchitecture benchmark (MandelX)
Reply 5 of 12, by appiah4
Falcosoft wrote on 2023-01-20, 09:31:
I meant to say 35FPS 🤣 Fixed.
Reply 6 of 12, by chinny22
I've a Diamond Stealth 200 (S3 Virge based) in a Pentium Overdrive 83, so slightly lower spec then your rig and Doom runs fine.
I do find it takes about an hour to get back into Doom if I havent played in awhile but after that hour you no longer notice the blocky graphics, frame rate etc. As you said we are spoilt these days.
But you can check how far off the 35fps your running at.
Type: doom -timedemo demo1
After that runs you'll get
x gametics in y realtics.
and do the following caclulation, the answer is your frame rate
x/y *35
Reply 7 of 12, by Syntho
I'll try that when I boot next.
The difference between Low/High graphic detail isn't that big, but it's noticeable. The framerate slows down very slightly and isn't quite as smooth as when on Low. I'm guessing that's normal, but wanted to be sure.
Reply 8 of 12, by theelf
Syntho wrote on 2023-01-20, 10:16:
On a P100 properly configured, with a good PCI Card you need to get constant 35fps, and no difference in low/high
test fastdoom engine, use for example vesa or Mode 13h version
FastDoom. A new Doom port for DOS, optimized to be as fast as possible for 386/486 personal computers!
Reply 9 of 12, by kixs
appiah4 wrote on 2023-01-20, 09:00:
They were. But very rare. He could be wrong with memory amount too 😉 Well, Virge chipset would have 4MB but it should run Doom without any slowdowns.
Reply 10 of 12, by leileilol
The only reason I can think of Doom being slow on a P100 is if it had a Rendition-based card, or an ill-advised ISA card of some kind, or a Sound Blaster Live eating the CPU for FM emulation, or there's no cache module.
Reply 11 of 12, by auron
a p60 will actually show minor framedrops/stutters in some areas with a lot of monsters, especially spectres. should be smooth on a p100 with proper PCI video and cache though, unless loading some heavy custom WADs.
Reply 12 of 12, by Syntho
chinny22 wrote on 2023-01-20, 09:57:
Type: doom -timedemo demo1 After that runs you'll get x gametics in y realtics. and do the following caclulation, the answer is […]
x/y *35
Low: 1710 904
High: 1710 1304
Good news though. In another thread I had an issue with my PC not booting. I figured out that the Turbo pins on the FPHeader shouldn't have been connected. Now when I switch between low and high it looks fine.
One issue I have though is that I'm seeing scanning lines in W95. They seem to disappear after a while. My other ISA card doesn't do that. Hmm. I guess it has to warm up?
EDIT: maybe with a full install of the Diamond software I could select its refresh rate and it'll look better...
