First post, by nd22
- Oldbie
It entered in my possession a long time ago a socket 7 board - Abit AX5 - which is in ATX form factor, has an Intel 430tx chipset and runs early Pentium up to 233mmx and first generation K6, so no, this is not a super socket 7 board!
Up until this year I did not have the time to test it or to build a system around it but I finally got the time so here it is:
1. Pentium 133 because that is all I could find to test the board as I was unsure if it was working or not.
2. 64mb of RAM on a double sided stick that I was lucky to have - the board is very picky with the ram!
3. Abit AX5
4. matrox millenium 2 8mb wram with very good VGA output but limited to 1280*1024 max resolution
5. WD 6.4gb hdd that is dead slow!
6. creative live sb0060 because all I have are different revisions of Live cards and nothing else.
7. corsair PSU
8. IDE CDROM
9. Intel stock cooler that is incredible noisy!
10. realtek 8139 NIC
I installed Windows 98SE from cd, chipset drivers from www.soggi.org, matrox drivers form the official website, creative drivers from Phils website and realtek drivers from www.soggi.org, however the performance was very poor, it took ages to run simple games such as Panzer General 2 - scrolling on the map was atrocius, same in Age of empires 1. I reinstalled everything with the same results; changed the HDD to a CF card and got the same results. I came to the conclusion that either the platform; the CPU, the ram or a combination of them is a bottleneck!
Formatted everything last night and installed Windows 95 OSR2.5; installed all the drivers but the realtek ones which I can not find. Performance is outstanding, system is very responsive, games run fine! The only problem remaining are the realtek 8139 drivers: I tried installing the drivers provided by Soggi however they did not installed! I have to mention that in 98SE USB ports are functional however in 95 despite having drivers installed there is no USB support!
This is my first socket 7 build so have mercy pls 😀
