First post, by kaiser77_1982
- Newbie
Hi there!
I have just found this rare item, but I can't find anything. Does anyone know or have this? I think it was canceled...
NVIDIA Offers Add-on Video to Digital Displays […]
Share on:
Recognizing the increasing use of digital displays in both home and corporate environments, NVIDIA Corporation today announced a new AGP riser card technology initiative, called the Digital Display Port (DDP).
NVIDIAs DDP specification provides OEMs, system builders, and motherboard manufacturers an opportunity to offer end-users an inexpensive waythrough the use of a low-cost AGP add-in cardto connect digital displays, including flat panel monitors and high-definition televisions, to PCs designed with an NVIDIA integrated graphics solution and an AGP expansion port.PCs utilizing integrated graphics solutions, such as NVIDIAs own nForce Platform Processors, include an AGP port that often goes unused, said Dan Vivoli, vice president of marketing at NVIDIA. By multiplexing the Digital Visual Interface (DVI) signal on the AGP bus, DDP provides a low-cost alternative that allows end users to upgrade to the latest in digital display technology, without having to compromise the high-performing graphics already integrated directly onto the motherboard.
Although the first DDP-based add-in cards will only work with nForce-based motherboards and PCs, NVIDIA has designed DDP as an open standard that can be implemented royalty-free by other PC core-logic designers and manufacturers. To date, DDP has already received unmitigated support from many of the industrys leading core-logic, display, and motherboard manufacturing technology companies, including ABIT, ALI/Acer Labs, ASUSTeK, Chaintech, Chrontel, Conexant Systems Inc., IDTech, Leadtek, LG/Philips, MSI, NEC/Mitsubishi, QDI, Samsung, Silicon Image, Sony, and Tatung.
NVIDIAs DDP proposal is attractive on many fronts, said Joe Hsieh, Director of Motherboards at ASUSTeK Computer Inc. For one, it is fully compatible with the existing AGP spec, and doesnt require any additional components or signal routing to our standard motherboard designs. By using the high-speed AGP bus to send the DVI signals to the digital display, end users can be assured of the best visual quality possible. ASUSTeK is very excited about the potential DDP brings to our customers.
Connecting PCs to different digital displays such as DVI and HDTV will greatly enhance the capabilities of the PC platform, said David Soo, President of Chrontel. This will open new markets and new applications for the PC industry and will dramatically help increase the proliferation and the use of digital displays on a global scale.
A DDP draft specification, including pin-out information, is available now from NVIDIA. Reference cards for testing and evaluation are available immediately from Chrontel, Conexant and Silicon Image. Samples of DDP add-in cards are also currently available from ASUSTeK, MSI and Leadtek. DDP cards supporting either DVI, TV-Out or both will be available later this year for approximately $20 USD.
Source: https://www.neoseeker.com/news/1550-nvidia-of … gital-displays/
