First post, by Ar2r4eg
Hi.
I have a strange noname 8bit vga card
https://ibb.co/dcHd194
All what i can find for it - that is from Olivetti computer and OEM.
Also on web i find that card possibly Prisma Graphics System VGA RT800.
I read bios from it, and in fisrs lines see "Olivetti" in dump.
https://drive.google.com/file/d/1m3KY5_ITE29v … ?usp=share_link
My problem is the standart utils for select video mode from WDC wont work with that card. Also i can't find anythig for this card - no jumper settings, manual, drivers or utils.
Maybe anyone who know Olivetti models line can help with identify it. I think need continue searching in OEM drivers for olivetti...
PS I find on Vogons old topic Re: WD90C11 and AT&T Model 6300 video mode as i know, for similar card. Try download and write bios but my card is won't show picture with it. Monitor on but out of range signal. (i have multisync with 30khz support)
My hardware:
enough for my wife to hate
Reply 1 of 14, by Jo22
Hi there!
I think I've got the same card in the attic somewhere! It's a nice antique, cool for testing purposes.
If you change the Olivetti VGA BIOS to a generic PVGA1A BIOS, it should work.
Tips:
- The Paradise Professional VGA (PVGA1A) is similar to the later WD90C00. Other revisions exist (1B, 1C etc).
- You can try the DOS tools in this thread: Re: 286 USIT Athena PC
- PCem emulates the Olivetti version, too, as "Olivetti GO481".
- It's possible to upgrade it to 512KB max, but that requires piggy-back (stacking the RAMs, modifying a pair of address lines).
Edit: This is also interesting!
Olivetti/Logabax/AT&T/Toshiba 640x400 hi-res graphics mode
Reply 2 of 14, by Ar2r4eg
Jo22 wrote on 2023-01-29, 17:43:
Hi there! […]
Hi there!
Tips:
Hi, thank you for answer.
I try DOS tools from first link, and as i expected it won't work with Olivetti VGA bios on this card. In mode select util i cal select only VGA color or VGA mono mode. Other tools report incompatibility of my model with WD VGA
Also i try use 32Kb bios from that tread WD90C11 and AT&T Model 6300 video mode but also does not work.
Can anyone help with original bios file from that card from WD ? (or any 8bit PVGA1A or WD90C00 based)
My hardware:
Reply 3 of 14, by mattw
I don't know how well known fact is, but Matrox MG-108 card is based around WD90C01 and IBM released this:
"Matrox Magnum Graphics Controller MG-104, MG-108 Option/Utility Disk v2.0 (11-23-90, 1.44MB)" :
http://www.walshcomptech.com/selectpccbbs/mg104108.zip
most interesting files (at least to me) on that IBM driver diskette are "Paradise 8514A Adapter Interface" TSRs :
* "WDAI4.exe" (for cards with 512K video RAM)
* "WDAI8.exe" (for cards with 1024K video RAM)
and the demo itself "WDDEMO.exe". I wonder if it works only on those Matrox MG-108 IBM used or on all WD90C0x-based cards. that's why I will be glad if someone of you test (in DOS just run the appropriate WDAI4 or WDAI8 based on the amount of RAM your card has and then run the WDDEMO).
I found the above files, when working on:
https://github.com/86Box/86Box/issues/2968
but if "Matrox MG-108" is compatible with more generic WD90C0x-based cards, then IBM released a lot of other files and drivers for it:
https://ardent-tool.com/video/matrox.html
that might be of interest to owners of such WD90C0x-based cards.
Reply 4 of 14, by Jo22
I'll have a look in my personal archives, too.
I'm pretty sure I backup-ed some VGA BIOSes in the past..
Edit: Found. Good luck! 😀 🤞
    paradise.zip
    29.71 KiB
    51 downloads
Reply 5 of 14, by Grzyb
Ar2r4eg wrote on 2023-01-30, 21:41:
http://vgamuseum.info/index.php/companies/ite … stems-pvga1a-jk
Nie tylko, jak widzicie, w tym trudność, że nie zdołacie wejść na moją górę, lecz i w tym, że ja do was cały zejść nie mogę, gdyż schodząc, gubię po drodze to, co miałem donieść.
Reply 6 of 14, by Grzyb
mattw wrote on 2023-01-30, 22:28:
There's a typo, actually it's WD95C01, from the WD9500 series - https://archive.org/details/bitsavers_western … 5WD9500_3838982
Nothing to do with the PVGA/90Cxx series...
Reply 7 of 14, by Ar2r4eg
Grzyb wrote on 2023-01-31, 11:27:
I try that bios. It's 64Kb but half fill of zero's. I Write it to 32Kb flash but card don't show image. Out of range on monitor, system booting in background. Same situation with any combinations of switches.
And that bios for PVGA1A-JK, on my card PVGA1A
My hardware:
Reply 8 of 14, by Grzyb
Try also these - http://vgamuseum.info/index.php/companies/ite … -systems-pvga1a
Though I think any should work, "JK" only means the package type...
Reply 9 of 14, by mattw
Grzyb wrote on 2023-01-31, 12:09:
thank you, It seems until now I always confused those two with one another. So, WD9500 series is the one that is 8514A clone!
Reply 10 of 14, by Ar2r4eg
Jo22 wrote on 2023-01-31, 09:32:
Hi, thank you. I try both files ftom archive. both not wotking with that card 🙁
I think we need to unpack the original and your files and see what the differences are there. And there is a suspicion that these files are from -JK chip, in HEX they are very similar to what I downloaded for -JK
My hardware:
Reply 11 of 14, by Jo22
Ar2r4eg wrote on 2023-02-01, 09:56:
Ah, I see. Too bad. I'll have a look at my physical card collection.
I do own a few EPROM programmers, too. Maybe I can do make some backups/dumps manually.
That would be more reliable than dumping the VGA BIOS in a PC, anyway. 😀
Reply 12 of 14, by Ar2r4eg
Grzyb wrote on 2023-01-31, 14:19:
That BIOS work ! YES !!! i write 32Kb file and got a picture !
I try switch to CGA mode - screens are attached.
1.92 MiB
BIOS info
1.56 MiB
VGA util. Mode for select
1.62 MiB
CGA test brw palette with corrupted text
1.81 MiB
Burgertime right palette
That card have no EGA mode.
In CGA mode done with compatibility test, right palette but corrupted fonts.
PS I use that drivers, thanks
VGA1024 util not work.
Guys , thank you so much for your help!
My hardware:
Reply 13 of 14, by Jo22
Afaik, on a real CGA card running in graphics mode, the text font inside of the PC BIOS is used.
That's because the CGA text font stored in the EPROM on the CGA card is not accessible via PC/CPU.
So the PC BIOS must use its own "duplicate" of a CGA font (which isn't necessarily the same as the one on the CGA card).
On a VGA card, this might be different, not sure. Depends on the VGA BIOS: Whether or not it overrides the CGA graphics routines inside the PC BIOS.
That's possible, if the BIOS is copyied into RAM by the PC during boot (Shadow Memory).
Reply 14 of 14, by Ar2r4eg
Jo22 wrote on 2023-02-01, 17:14:
Afaik, on a real CGA card running in graphics mode, the text font inside of the PC BIOS is used. […]
Thank yot for answer. When test i use DOS 7.1 from Win98 setup. After i install clear MS-DOS 6.22 problem with fonts is gone !
My hardware:
