First post, by vgeorgiev
Hello,
I got the main board on the picture. However Y2 oscillator (bottom right) is missing. I wonder is what is the value of the osc.
1.05 MiB
Reply 1 of 3, by Horun
Have not had time to track down the exact board BUT In your picture the 66.6667Mhz black rectangle (in red highlight below) should be the main CPU/BUS crystal. That would support a 33Mhz CPU. The Y2 missing crystal is for Async operation of the Math-co (goes in the W 3167 socket). The green highlights are where I see green corrosion on a quck inspection, see your posted picture, mine is shrunk and just for reference....
    309.56 KiB
Reply 3 of 3, by vgeorgiev
I treated the corrosion with some vinegar. I put the CPU. It is 486DLC which is pin to pin compatible to 386 😀
The mainboard works.
https://www.youtube.com/watch?v=RPdYothcqGw
Still couldn't find any info about the board.
