First post, by cambalinho
is there a KernelEX for windows xp?
Reply 1 of 10, by elszgensa
A name that keeps cropping up in discussions like this is "One-Core-API" which has similar goals, but I have zero experience with it myself.
Reply 2 of 10, by Jo22
Ah yes, I remember! Thanks for the info! 🙂👍
Wasn't it somehow releated to the Shorthorn project, too ?!
Reply 4 of 10, by BEEN_Nath_58
The developer mentions that One Core API would run Assassin's Creed 4 as well as Crysis 3. Aren't they 64-bit binaries? Well that's something I wouldn't believe till I test. Since my WinXP machine is inadequate for these games, could someone verify if it's really possible?
Reply 5 of 10, by DosFreak
Both Black Flag and Crysis 3 are 32bit.
OnecoreAPI is for both XP and 2003 32bit and 64bit.
As far as comparing two different games performance I'm not sure why someone would bother unless there was a performance issue that OneCoreAPI would solve, mabye it's being mentioned due to possibly wined3d being used with a version of d3d that XP does not support.
I have Black Flag in an XP folder which usually means I tested it on XP but I'd have to verify. Mabye I used Wined3d....
I can't remember if Crysis 3 works on original XP but I want to say not.
/EDIT
Black Flag requires at least Vista unless using OneCoreAPI
Crysis 3 requires at least Vista unless using OneCoreAPI
Make your games work offline
Reply 6 of 10, by djsabreblade
crapsis 3 does not work on xp 32 bit if it were possible it would be all over youtube by now. there is only one video that claims to have it running on xp however i think its definitely fake
Reply 7 of 10, by cambalinho
I tested, but on 'COMPATIBLE', i can't see above windows 2000, but some error text.
OneCoreAPI have 4 or 5 patches, they have an order or something?
Reply 8 of 10, by cambalinho
finally i installed.. but i lose the Windows Activation 🙁
is there another patch?
Reply 10 of 10, by cambalinho
i have too.. but the OneCoreAPI smach too much so i can't activate it 🙁
reformat the pc, AGAIN, but anyone knows another patch for Kernell Extended? i try the XP Extended, but i get a win32 error like been invalid.. my system is 32 bits\X86
