First post, by matti157
Hi, I'm trying these 2 VGAs and I don't understand why I have such a big difference at 3dmark. They are very similar cards
Computer and drivers are the same for both cards, I am swapping between one card and the other without even uninstalling the drivers
Specifications:
https://www.techpowerup.com/gpu-specs/quadro-fx-3450.c1368
https://www.techpowerup.com/gpu-specs/quadro-fx-3400.c1367
With the 3450 I get about 12000 points.
1002.88 KiB
With the 3400 about 5700
1.52 MiB
Why the difference? Is the 3400 broken?
Reply 1 of 12, by matti157
I tried to unlock the 16 pipelines with Rivatuner but gained only little, I don't understand. 3450 kills it
1.56 MiB
Reply 2 of 12, by matti157
And now, Afterhours unlocking pipelines, I overclocked it to 400/1000 like a 6800GT
But the result is 6800 😅
6800gt: https://www.techpowerup.com/gpu-specs/geforce-6800-gt.c130
But why is the 3450 much faster despite now also having fewer pipelines? I am going crazy
Reply 3 of 12, by pentiumspeed
Both are 5:12:12:12 but 3400 is run at 350MHz with ram at 900MHz. FX3450 is nearly 75MHz more with ram at 1GHz and cooler.
Also the die is completely different. 3400 is NV40/NV45GL while 3450 is NV41. These are pulled from wiki.
Cheers,
Great Northern aka Canada.
Reply 4 of 12, by Imperious
Must be driver related. I suspect if You were using WinXP with non modded drivers You wouldn't have this issue.
Justout of curiosity what are the rest of the system specs?
Reply 5 of 12, by matti157
Tomorrow I try with xp
I saw now that Nvidia, however, has made official drivers for 9x that support the 6XXX series and the Quadro 3XXX. I don't need to install the unofficial ones then https://www.nvidia.com/it-it/drivers/win9x-archive/
The rest of the configuration is:
-Asus Sabertooth X58
-i7 930 @1.8ghz single core only
-1gb RAM
-Audigy SB0090
-Integrated network via ndis 2
Reply 8 of 12, by agent_x007
AIDA64, maybe Everest Home (if you want 100% free), HWInfo should be able to do it as well (GPU-z can do it, but that's WinXP+).
Card may have damaged traces or filtering caps to/from PCI-e slot, which prevents it from running at full x16 speed.
It doesn't matter what other cards can do on the same slot at that point.
Reply 9 of 12, by matti157
Imperious wrote on 2023-02-09, 00:21:
You won. On Windows XP with the latest available driver these are the results:
Stock
1.92 MiB
16 pipelines unlocked
1.87 MiB
Now I have to figure out which driver to use on Windows 98, I don't want to be forced to switch to XP
Reply 10 of 12, by pentiumspeed
Which card you can unlock for 16 pipelines? FX3400, or 3450? or both types can do that? Since I have some of these somewhere.
Cheers,
Reply 11 of 12, by matti157
pentiumspeed wrote on 2023-02-10, 23:37:
Cheers,
The FX3400 can be unlocked because it has the NV45 chip. The FX3450 does not, it is NV41
