disable driver signing
First post, by djsabreblade
just wondering if someone here could help me disable driver signing in win7-64 i can't figure out how. trying to install latest hd 7970 adrenaline driver thanks!
Reply 1 of 2, by Warlord
Before windows boot press F8, like youre going into safe mode, but instead chose test mode its towards the bottom of options.
You can also use Bcdedit.exe -set TESTSIGNING OFF or TESTSIGNING ON reboot required.
Its easy.
Reply 2 of 2, by djsabreblade
Yes tried that. latest driver installs with errors but still says in device manager ''it needs to be signed'' or something and will not start. the previous driver does work although the hdmi driver doesn't. any ideas?
another problem i have is i cannot overclock at all at 144hz in windows 7 without graphical glitching. at 75hz no problem. in windows xp i can no problem
