First post, by edek
Hello. I wanted to say hello. This is my first post here 😀
I have a SMARTEK 860407 motherboard https://theretroweb.com/motherboards/s/precis … -precise-860407
On1uwFL.jpg?1
I don't know how to enter bios. Or go further. I would like to install MS DOS
Computer has HDD (no original controller)https://stason.org/TULARC/pc/hard-drives-hdd/ … -MFM-ST412.html
2 x 5.25 floppy (no original controller) added GoldStar Prime 2 9420
I have already ordered the HDD controller. I'm waiting for the shipment
I tried to enter the Bios with the keys, but it did not work (ctrl+alt+insert,esc, F1, etc.) I tried to connect the gotek but without success. at startup it communicates with gotek but nothing happens.
I will be grateful for all advice and suggestions. Regards
Reply 1 of 11, by pentiumspeed
That vintage, you need compatible CMOS setting program for phoenix bios that you run from DOS. I had done that before.
Get it booting first. May need to use 720K or 360K disk boot disk with cmos setup program.
Cheers,
Great Northern aka Canada.
Reply 2 of 11, by Anonymous Coward
I think Gsetup is compatible, but you might want to use a patched version that doesn't corrupt the settings.
Reply 3 of 11, by Horun
If Gsetup does not work: https://www.minuszerodegrees.net/5170/setup/5170_gsetup.htm
I have two old Phoenix setups, one from 1986 the other 1989. I suggest you try the 1986 one first.
Reply 4 of 11, by maxtherabbit
None of the keys are working because you are getting a keyboard error. Read the POST screen. Something is wrong with the keyboard interface
Reply 5 of 11, by Horun
maxtherabbit wrote on 2023-02-16, 02:50:
🤣 I missed that, good eye !
Reply 6 of 11, by Vic Zarratt
Agghhhh! this is reminding me of the IBM setup bios diskette i've been searching for my Panasonic CD-V21P - an absolute curse!
I manage a pot-pourri of video matter...
Reply 7 of 11, by edek
This is a photo from the first launch. There is no message at this time.
Reply 8 of 11, by wbahnassi
Try Ctrl+Alt+S or Ctrl+Alt+Esc any time the computer is waiting for input.. some BIOSes work like that.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, FDDx3
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 9 of 11, by edek
wbahnassi wrote on 2023-02-16, 11:45:
Unfortunately. I've already tried everything. But thanks for the advice. I also connected different keyboards.
Reply 10 of 11, by edek
Horun wrote on 2023-02-16, 02:29:
It started. Thanks Horun!!
A friend recorded a floppy disk with dos5 and files from the attachment. I don't know which one worked. But it started
Thanks friends for your help.
Reply 11 of 11, by Horun
Great ! Hope you can get it configured proper.
Vic Zarratt wrote on 2023-02-16, 03:17:
Panasonic removed all drivers/util for their old laptops in 1995 according to the archives.
There are a few setup's for desktops, maybe one of them might work for your lappy....
http://vogonsdrivers.com/getfile.php?fileid=1965&menustate=0
