First post, by nadmin1706
nadmin1706
Offline
Hello Experts,
I need your help to the RGB to HDMI project by hoglet and ianb.
My idea is to replace the buildin CRT video monitor with an HDMI output.
In my test i want to modify a willtek stabilock 4032.
I have the following signals from the digital grafik unit.
- Green pal video signal without csync (TTL Level)
- H-sync 15,625 Hz TTL Level
- V-sync 50 Hz TTL Level.
Is it possible to modify the 3 bit RGB to HDMI adapter to support separate H + V sync signal.
I hope someone can help me
kind regards
Matthias
