First post, by ptr1ck
I have an opportunity to use an EVGA GTX 970 4gb in my XP/10 box instead of my Asus GTX 760 2gb. However, the 970 has a lot of coil whine and is only putting out about 5% higher score on 3D Mark 06. I have tried another PSU on hand and it did not improve the whine any nor the score. I have also ran 3d Mark 06 in Windows 10 which did not bench as high as XP.
I would like to use the 970 as I dual boot and it's still more than capable of playing modern games with 4gb, but the noise trade-off for little performance gain is not what I want. I was expecting 20-30% higher performance. Any suggestions for what direction to go here? I'm willing to solder on the 970 if needed, but doesn't seem to be worth it for little gain. Could whatever making it whine also be killing performance? Do I need to use a different test to quantify the performance difference between the two?
Edit: Forgot to mention the rest of the system is a 4.0ghz i5-2500k with 16gb RAM.
"ITXBOX" SFF-Win11
KT133A-NV28-V2 SLI-DOS/WinME
Reply 1 of 3, by agent_x007
Don't use 3DMark 06, use at least 3DMark 11 to compare those cards.
Your CPU has too much of an impact on overall score with those fast DX11/12 GPUs.
Here's similar comparison (GTX 680 vs GTX 980 [clock sync'ed]) on my main PC :
3DMark 06 : https://www.3dmark.com/compare/3dm06/18244072/3dm06/18245573
3DMark 11 (P-Score) : https://www.3dmark.com/compare/3dm11/15526234/3dm11/15549893
If you want to do a compare between OS (so test must work on WinXP + Win10) - use 3DMark 03 instead :
https://www.3dmark.com/compare/3dm03/6555653/3dm03/6555823
(with fast enough CPU, it should be easier to see actual performance difference)
Both of those versions ('03 and '11), are free to download from legacy 3dmark website :
https://benchmarks.ul.com/legacy-benchmarks
As for coil whine, use some tape or glue to change their resonation frequency.
Reply 2 of 3, by The Serpent Rider
You don't play 3DMark06.
Won't help you, unless you have good understanding of card schematics and inductors in general.
https://www.youtube.com/watch?v=4D6PKusyvUU
...or hot glue. Lots of hot glue.
Reply 3 of 3, by ptr1ck
I did run 03 on my 760 but forgot the score. I'll try some more tests later. It's mostly for Windows XP so the 760 I have ought to be more than sufficient if I go that route. I have plenty of other faster machines for modern games.
edit: OK so thanks to agent_x007's advice, I tested with 03 and there was a difference of 98999 with the 760 to 136360 with the 970. I also forgot that it turns off vsync and the high frame rates is what makes it sing. I am a vsync on kind of guy, so I shouldn't have any worries.
"ITXBOX" SFF-Win11
