First post, by microtronichamburg
The membrane / flex cable connectors of my Schneider Euro PC keyboard were not salvageable.
So I made my own, as well as a connector. I should know shortly if it works. Stay tuned for another update!
It's a 0.2 mm PCB.
https://youtu.be/TPmV74Tdfdg
    196.42 KiB
    182.04 KiB
Reply 1 of 5, by microtronichamburg
Adapter board is still in production. But so far, it looks promising. The LEDs are verified working, and pushing a button lowers the resistance to ~70 Ohms, which is OK. Same as with the original. After all, the key stamps are only conductive rubber.
Reply 3 of 5, by hyoenmadan
Does PCBWay manufacture membranes for keyboards? I have a Thinkpad 800x whose membrane got its flex connector fractured, and even with the copper strip fixed I did to it, sometimes fails to register some keys (which means wasn't completely fixed and it still is degrading).
Reply 5 of 5, by microtronichamburg
Finally back together...
