First post, by X_Tra
 - Newbie
Hello!
I've discovered that Dosbox 0.63 has some problems with long filenames (i.e. not in 8.3 DOS format).
I'm from Russia, my system is WinXP RUS, I have 2 physical harddisks, and they are splitted into 5 logical volumes in FAT32 filesystem. I'm not sure, but I suppose that all filenames are encoded in Unicode (especially those in Russian language).
Now imagine I have a folder with two files (ISO-images) of similar filenames (first 15 symbols of the filenames are exact), for example:
[LONG_FILENAME] filename1.iso[LONG_FILENAME] filename2.iso
The first filename is >64 symbols, the second is <64 symbols (not like in example). ISO-images are valid (i.e. not corrupted and can be mounted). Now I want to IMGMOUNT them in Dosbox as X: (not simultaneously, of course). I mount my harddrive as C:, set current dir to that folder, then type DIR and get list of two filenames. Because first 15 symbols of filenames are exact, in DOS format they are available for Dosbox as:
[LONG_~1.ISO[LONG_~2.ISO
Well, I type
IMGMOUNT X [LONG_~1.ISO -t isoIMGMOUNT X [LONG_~2.ISO -t iso
But Dosbox says, that both files are not found. I tried many times, but no result - same error...
Well, I rename both files (prefix removed):
filename1.isofilename2.iso
The first filename is still >64 symbols, the second is <64 symbols
IMGMOUNT X FILENA~1.ISO -t isoIMGMOUNT X FILENA~2.ISO -t iso
Now the second file successfully mounted (X:\DIR works), but IMGMOUNT says that it was wrong syntax on the first command...
Well, OK, I rename the first file so it is <64 symbols now. After this first command successfully mounts ISO-image as X:
This situation is very strange, I think it is a combination of ISO filename length limitations, wrong parsing some symbols in Dosbox, and my hdd filesystem...
P.S. If I type filenames in quoted format (not 8.3), then removing prefix from the first attempt to the second is not needed: on first attempt I get results like in the second attempt, i.e.:
IMGMOUNT X "C:\Path_to_file\[LONG_FILENAME] filename1.iso" -t isoIMGMOUNT X "C:\Path_to_file\[LONG_FILENAME] filename2.iso" -t iso
mounts second image, and says about wrong command syntax for the first one. After decreasing first filename length to fit in 64 symbols everything works fine...
This message is supported by X_Tra Systems
