First post, by Parni
I started to play around with 3DMark99 after a really long time, I noticed the benchmark gives me different score every time??
I don't remember from more than twenty years ago was this normal behavior for the benchmark?
My system is P3 800MHz/TNT2 Ultra/256mb/Win98SE
Reply 1 of 4, by Gmlb256
If the differences are small, it is within the margin of error which is normal.
Reply 2 of 4, by Parni
Scores varies between ~7000-7500
Reply 3 of 4, by elszgensa
I assume those scores were collected at the same time (same room temperature etc)? If not, time for a do over. Also, drop the first result you get, from when your components are still cold in the beginning. Are you still seeing as much variance then?
Reply 4 of 4, by Parni
Actually they were not collected at the same time, I need to try once more. Could temperature effect so much? (Clocks remaind the same regardless the temp?)
