First post, by sofakng
What is required for playing 1990s FPS games at SVGA (60 fps) ?
I have a Pentium 3 500 MHz from an IBM PC and it appears to include "S3 Trio 3D" chip onboard. Would this be possible to play 1990s FPS like Duke3D/Quake at 800x600 with 60 FPS?
If not, is there a recommended PCI video card I should look into? This motherboard doesn't have AGP so I'm limited to PCI.
Reply 1 of 7, by feda
Should run quite well at 800x600, yes. Not sure how it would fare if you want to go above that.
Reply 2 of 7, by The Serpent Rider
Stable 60fps? Duke Nukem 3D - yeah, probably possible, but not with S3 Trio3D. Quake - just nope.
Matrox Mystique/Millennium II was a popular 2D choice back then.
Reply 3 of 7, by rasz_pl
you will need to enable write combining to get good video speed in dos
https://bearwindows.zcm.com.au/af.htm
MTRRLFBE http://rayer.g6.cz/programm/programe.htm
Reply 4 of 7, by sofakng
Thanks for the advice.
What about the combination 2D/3D cards like the Riva TNT(2) or Voodoo3? Are they better for 2D software rendering than the Matrox cards?
Reply 5 of 7, by feda
I remember getting good performance in Duke3d with a TNT2 card, though I haven't used mine in ages. It's a little newer than the Matrox cards mentioned.
Reply 6 of 7, by kolderman
sofakng wrote on 2023-03-02, 19:02:
Voodoo3 has excellent 2d image quality, and probably performance. By then Matrox was known for professional, multi-head cards that did quality color reproduction in a way that was of no interest to gamers, just graphic artists.
Reply 7 of 7, by AlexZ
UniVBE helped with Duke3D performance for sure on S3 Virge DX2. Not sure about S3 Trio 3D or 60fps. 800x600 should be playable on PIII 500. Back in the day we used to play it on 640x480 on K6-2 350.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
