First post, by Blurpje
Hi there all:-)
ik got here a "Fujitsu icl indiana" a want to reset the bios but i can't find the bios battery on the motherboard, maybe I'm looking over it but there should be a bios battery on it, right?
thanks in advance, Marcel
Reply 4 of 6, by bogdanpaulb
There are jumpers near the Dallas RTC , but the img is to blurry to be able to read the description .
    808.03 KiB
Reply 5 of 6, by Baleog
Blurpje wrote on 2023-03-03, 14:07:
Hi there all:-)
I believe this is your motherboard:
https://theretroweb.com/motherboards/s/icl-indiana-d-series
You can find the jumper settings under download. I am guessing you want to try to short pin 2-3 on JP2 to disable the password.
If that doesn't work you need to flash a new bios, but try the jumpers first.
Mixed PCs - Midi racks - Micros and more
Reply 6 of 6, by Blurpje
Baleog wrote on 2023-03-04, 09:28:
I believe this is your motherboard: https://theretroweb.com/motherboards/s/icl-indiana-d-series […]
Hi there all:-)
I'm gonna look into this, thanks!
