First post, by eddman
I've set up a machine with a PMMX 200 and Windows 98 SE.
Under windows duke3d spends just ~3 seconds on the loading screen the first time, and subsequent launches are ~1 second.
However, in DOS mode, it takes ~25 seconds and there are major stuttering/hitching in the menu demo and while playing. PCem's emu speed is 100% during all stages, so it's not that.
I use "Restart in MS-DOS mode" and these are the boot parameters:
config.sysDEVICEHIGH=C:\DOS\VIDECDD.SYS /D:OPTICAL
autoexec.batLH MSCDEX.EXE /D:OPTICALLH C:\DOS\MOUSE.COM /p4
I've also tried Phil's custom PIF file, but the results are the same. Any suggestions?
