First post, by AppleSauce
Hiya anyone that can help , I've got a bit of a setup in the works involving a DB25 switcher and some LPT sound cards.
And I was just wondering if my setup would be feasible or not.
The attachment 20230301_171741.jpg is no longer available
So I've got the printer port and audio cable bits figured out.
But the main issue is supplying power , so since both LPT devices need to be powered by a USB mini A type cable and my pentium motherboard only has 2 usb ports and I want to keep one for transferring stuff via USB, I was wondering if I could this?
So USB mini A would go into the LPT device and the regular A side to the USB switcher ,
The attachment SKU27__55181.jpg is no longer available
The attachment s-l1600.jpg is no longer available
which uses USB type B so id use a converter to hook it in ,
The attachment s-l1600.png is no longer available
then a usb A to usb A would go from the switchers out to the PCs usb port to power it.
The attachment Capture.PNG is no longer available
I figured id ask cause there was stuff i saw on the web about usb power only being able to go in a single direction and I don't want to blow anything up.
Reply 1 of 6, by BitWrangler
Hmmm, that looks like a 2 machines to one USB peripheral switcher. Not sure it's gonna work that way... I'd just plug them both into a powered hub or use a 2 port wall wart.
Reply 2 of 6, by AppleSauce
BitWrangler wrote on 2023-03-08, 05:53:
Damn I was worried it might not work , I don't really have any free outlets left on my power strip so I was trying to find another solution , I'm guessing a non powered hub wouldn't work on a socket 7 motherboard?
Reply 3 of 6, by Horun
Hmm you could try one of the following: 3 or 4 Port USB Wall Charger ($10) or a 3 way AC add-on ( maybe only $4) to add to your surge strip (since the little wall warts won't pull much of a load.
just a thought 😀
Reply 4 of 6, by AppleSauce
Thanks for all the suggestions guys im keeping all the options in mind.
Just wondering then would the reverse work?
The attachment usb-switch-box-abcd-1-type-b-4-type-a-ports-2.gif is no longer available
Something like that?
Reply 5 of 6, by AppleSauce
I also found this.
The attachment s-l400.jpg is no longer available
Reply 6 of 6, by rasz_pl
you dont need usb hub just to share 5V power. You dont need usb at all to power your 5V devices, plug into one of the MOLEX connectors on the psu inside the computer.
