First post, by SavageKurtain
So, i decided to expand the RAM of my old Compaq EVO N1020V laptop, 1,50 GHZ Intel Celeron processor.
I decided, at first, to buy a DDR 400 (PC3200) 1 GB RAM, but it turned out that the base RAM that was inserted in the laptop was a DDR 266 (PC2100) 256MB RAM.
Is it possible to use a more powerful RAM, or do i have to buy same DDR 266 model, but with more memory?
Reply 2 of 8, by dionb
Within each standard (DDR1 in this case), speeds are backwards compatible. Also, the DIMM itself doesn't clock anything, the memory controller on the motherboard does.
So see a speed indication as the speed limit on a road: staying under the limit is always safe, going faster risks crashes. There's no problem at all with running slower.
What might be a problem though is the capacity/density of the SO-DIMM. The Evo N1020V has an ATi RS200M chipset. I'm having trouble finding clear specs for the chipset, but the laptop indicates a max memory of 1GB using both SO-DIMM slots. I strongly suspect that it can handle max 1Gb chips (note the lower-case b, this is bits not Bytes), which works out at max 512MB per SO-DIMM. If you want 1GB of RAM, you will thus need two 512MB SO-DIMMs rather than a single 1GB SO-DIMM.
Reply 3 of 8, by SavageKurtain
dionb wrote on 2023-03-09, 14:54:
I've read the instructions of the notebook, which i've found on a site:
Yeah. it seems that it uses 512mbX2. I've found two on Amazon, but... is it a problem if they are not Compaq original, like the manual suggests?
The 256MB ram it's a Samsung, but it's branded as Compaq spare part.
Reply 4 of 8, by dionb
SavageKurtain wrote on 2023-03-09, 15:30:
That's mainly rear-end covering: they can't guarantee stuff so they only recommend what they can guarantee.
Unlike in the SDR-SDRAM period, in DDR1 things were pretty straightforward. The only thing to watch is that you need double-sided (16-chip) SO-DIMMs. Very late 8-chip SO-DIMMs will only be half detected.
Reply 5 of 8, by SavageKurtain
dionb wrote on 2023-03-09, 15:59:
The one i chose seems double sided, so it should work, right?
Reply 6 of 8, by Gamecollector
I not seen PC3200 DIMMs w/o PC2700 and PC2100 timings in the SPD chip.
Dunno about "PC1600 only" chipsets...
Reply 7 of 8, by red-ray
Gamecollector wrote on 2023-03-09, 18:11:
I don't see the point to your post as I have, the first two systems I checked had PC-3200 DIMMs that do not have all 3 sets of timings.
file.php?id=159375
    66.2 KiB
Reply 8 of 8, by Horun
Agree red-ray. Have witnessed some DDR 333 and 400 that have only 166. Not all SPD are programmed the same 😀
