Make an hard disk backup
First post, by Nemo1985
Hello, I've found an old 176mb disk with a windows 95 installation, I'd like to make a full backup out of it.
Like an image but I'd like also to be able to open in and retrieve files.
I can connect it to a windows xp machine.
Any good program to do so?
Thanks
Reply 1 of 4, by konc
It's so small that, apart from the image, you can also keep a .zip with the contents to easily copy files from it.
Reply 2 of 4, by weedeewee
under linux
dd if=<harddrivetobackup> of=<harddrivebackupfile>.img
You can use osfmount in windows to add, remove or list files in the image.
linux should also work though given the partition table in the image, I don't know how.
Do not ask Why !
Reply 3 of 4, by Ryccardo
weedeewee wrote on 2023-03-11, 09:48:
losetup -P /the/full/disk/image to mount a whole virtual disk, then you can mount/format/copy/whatever the individual partitions, then once you're finished losetup -D to unmount all loop* virtual drives (or: -d loop? for only one) 😀
Reply 4 of 4, by Nemo1985
Thanks I will give it a try, any advice about what live distribution to use?
