First post, by Pierre32
I have an Asus Eee PC 701, which has a resolution of 800x480. It has some potential as a retro gaming machine, but has languished in a cupboard for years for the crime of being not very interesting.
SBEMU changes this, turning the 701 into a powerful DOS machine with Sound Blaster support. A modern Libretto! With one downside - everything is stretched to fill the screen. The Libretto 100CT (also 800x480) had a toggle in BIOS allowing you to have unstretched 640x480, but Asus offers no such option.
I've read the FreeDOS docs about setting display modes in nansi.sys, but the process was a little hard to understand, and even then I wonder if it's the correct tree to bark up. Is there a way to do this, via FreeDOS config or otherwise?
Reply 1 of 7, by acl
If it's running Linux, xrandr can be used for that.
EeePc has a VGA out iirc. Can probably display 4:3 on an external display.
I had a 701 back in the days (used it all my University years). Great little machine. Loved it.
Reply 3 of 7, by Pierre32
Thanks for the replies. Just looking to use this as a DOS netbook, so an external display isn't on the cards. I'll enjoy it as-is for now and hope that a solution falls out of the sky.
Reply 4 of 7, by sledge
Well then, hello again after three years! 😀 I still can’t stop thinking about forcing a 4:3 aspect ratio on the Asus Eee PC 701 under DOS, and with every new generation of AI I try to get a little further through some infernal vibe coding.
With GPT-5.6 Sol, I finally managed to put together something semi-functional: the EEEFIT utility can actually force a centered 4:3 image with black borders. However, when a game starts - that is, when the graphics mode changes - the picture shifts to the left and garbage appears on the right-hand side. The 4:3 aspect ratio remains intact, though. 😀
At this point I seem to have hit a wall. It probably cannot be taken any further without turning it into a resident program. I am including a download link for both the source code and the compiled EXE.
https://high-voltage.cz/_dl/eeefit.zip
doshaven.eu / high-voltage.cz
Reply 5 of 7, by sledge
And here it is: a working DOS resident utility that forces the display to a 4:3 aspect ratio. It assumes JEMMEX / JEMM386 and HDPMI32.EXE - this specific configuration was chosen with SBEMU in mind. As I said before - this is the result of some hellish vibe coding with ChatGPT 5.6 Sol. But it seems to work 😀 Tested with Doom, Duke Nukem 3D, and Commander Keen 4.
https://high-voltage.cz/_dl/EEEfit_1.0.zip
Reply 6 of 7, by Pierre32
Pierre32 wrote on 2023-03-11, 21:22:
And behold, something fell out of the sky.
sledge wrote on 2026-08-09, 11:07:
Thanks sledge for your efforts on this! My EeePC is currently at a different address, but I'm keen to test as soon as I can.
Reply 7 of 7, by ntalaec
It's possible to port this to use it with Intel 945GM with 1366x768 screen resolution?
