First post, by douglar
I have a 256KB 5150 motherboard.
I tried powered it up with P8 & P9 situated correctly, no cards installed, but heard a slight pop and smelled a faint burning odor.
I powered it off and didn't see any damage. I looked over the capacitors with a magnifier and didn't see any burn marks or holes.
Now when I try to power up the board, the power supply just shuts off like there's a short, no power.
Any advice where to look next for the damage?
958.96 KiB
Reply 1 of 12, by pentiumspeed
Inspect very carefully of each C7 3 legged capacitors, one of them might be cracked or blackened.
Use lens if you can borrow.
Cheers,
Great Northern aka Canada.
Reply 2 of 12, by weedeewee
figure out which power rail is shorted.
+12v, +5v, -5v, -12v or PG
if it's the +-12v or -5v rail, it's going to be a capacitor.
if it's the 5v rail, it's likely a capacitor but it can also be one of the ICs.
If you have a bench power supply, you can hook it up to the shorted rail and figure out by touch what gets hot. limit it to half the max voltage the rail can do and limit the current to 1A.
fyi, the cap in the middle of the photo looks a bit sus to me.
Do not ask Why !
Reply 3 of 12, by pentiumspeed
pentiumspeed wrote on 2023-03-12, 22:04:
Inspect very carefully of each C7 3 legged capacitors, one of them might be cracked or blackened. These 3 legged capacitors are tantalum and they tend to fail at power on and short out with a bang.
Cheers,
Reply 5 of 12, by Nexxen
When possible, could you post 4 pics of 4 quadrants of the board.
The pic isn't hq enough to see clearly.
Hope you solve as this is a very nice board. Really nice!
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 6 of 12, by douglar
Nexxen wrote on 2023-03-12, 22:28:
It is a nice board. I was really sad when the magic smoke came out.
549.86 KiB
1.03 MiB
1.05 MiB
1 MiB
Reply 7 of 12, by Nexxen
Below D8255 chip, T02 is a rifa? (the green square, vertical standing 😀)
A corner facing the D82 looks chipped.
Tried removing all ram chips?
Edit: add 3rd pic, top right yellow tantalum with a black spot, unless it's dirt.
Reply 8 of 12, by Horun
Is the oddness on the end of 8237 left over stuff from a sticker ? I cannot see any thing like burned cap or trace.
Does the relay have a funny smell ? What does the back of the board look like ? Just curious.
Reply 9 of 12, by douglar
Horun wrote on 2023-03-13, 00:50:
The back of the board is fine, but the 8237 is strange. The discoloration didn't come off with water or naphtha.
It looks like the plastic might have cooked.
I'll try replacing it.
Reply 11 of 12, by douglar
DerBaum wrote on 2023-03-13, 02:23:
Have you tried to measure for shorts on each power input? It could lead you to a shorted powerrail wich can lead to a shorted capacitor.
Ok, that’s easy enough. I’ll try that tomorrow
Reply 12 of 12, by douglar
Yes, the +12V is shorted to ground
And it is this capacitor right here:
44.21 KiB
This page looks like it's got the info I need for the capacitor replacement.
https://www.minuszerodegrees.net/failure/IBM% … 0capacitors.htm
Makes me want to make sure my old XT gets power every 6 months instead over every 2 years.
