First post, by iraito
I'm trying to install any driver wdm or vxd, from original discs and what not, the moment the card gets recognized the system freezes.
Any suggestion? Besides changing OS, for now i want to see if i can solve this on ME.
If you wanna check a blue ball playing retro PC games
MIDI Devices: RA-50 (modded to MT-32) SC-55
Reply 2 of 6, by Joseph_Joestar
iraito wrote on 2023-03-17, 16:35:
I don't think it has anything to do with the OS, since I've been using that exact Audigy model on WinME for nearly a year now. No problems whatsoever, and that's with VxD drivers.
You might possibly have a resource conflict or a hardware issue.
Reply 3 of 6, by shevalier
Audigy has been around for over 20 years since its release.
It often has dry electrolytic capacitors near to both 1117 regulators.
For start, these capacitors need to be replaced.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 4 of 6, by iraito
It was daemontools, apparently on winME 3.47 usually ends up crashing the OS on startup, version 3.44 is recommended.
Reply 5 of 6, by shevalier
iraito wrote on 2023-04-04, 13:52:
I thought you were experimenting on a clean freshly installed system...
Reply 6 of 6, by iraito
shevalier wrote on 2023-04-04, 15:20:
I'm so accustomed to install daemon on a freshly formatted system my brain just accepted it as a fact of life 😅
