First post, by Shponglefan
I tried running NFS: Porsche Unleashed on my Windows 98 SE setup with a GeForce4 4200 Ti.
While it lets me select it as a graphics option in the 3D setup, in-game the main menu does not display any proper textures. I just get a bunch of empty rectangles.
I also have a Voodoo2 installed and using that card, the game has no issues. It just won't let me run in a resolution higher than 800x600.
I'm running Windows 98 SE, nVidia drivers version 77.72, and I've tried both DirectX 7.0a and DirectX 8.0 with the same results.
Any suggestions on options? Should I try different nVidia drivers? Or is this just an incompatibility with the Geforce4, similar to NFS 3: Hot Pursuit?
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 1 of 4, by Joseph_Joestar
Shponglefan wrote on 2023-03-25, 05:42:
That's your problem right there. Those drivers are way to new for Win9x gaming. Try something like 30.82. Unless your card is of the AGP 8x variety, in which case go for 45.23.
I don't remember any particular GeForce4 incompatibilities with NFS3, other than the lack of fog on non-Voodoo cards. What problem did you encounter exactly?
My retro stuff
Reply 2 of 4, by Gustl
the voodoo I could not only do 640 x 480 and the voodoo II only a maximum resolution of 1024 x 800.
Maybe try with a lower resolution?
Reply 3 of 4, by Shponglefan
Joseph_Joestar wrote on 2023-03-25, 06:17:
Thanks, the 30.82 drivers worked!
In hindsight I'm not even sure why I even had the 77.72 drivers installed. Though I think at one point I was testing GeForce 6800 in this system and probably never switched the drivers back...
Same issue as with NFS: Porsche Unleashed. Though with the 30.82 drivers, NFS 3 also ended up working.
Reply 4 of 4, by Shponglefan
Gustl wrote on 2023-03-25, 09:41:
To clarify, the issue wasn't with the Voodoo2 card. It worked fine.
The issue was with the GeForce4 which has now been resolved via downgrading my drivers to 30.82.
