First post, by Sinchin
Hey folks,
i recently created an old Win98/DOS computer, everything is working fine, except i cant get sound to work in DOS. When starting "Diagnose.exe" or the setup for Duke Nukem 3D i can hear music, but no sound. I do not get error messages though. It seems to be playing those testsounds, but i just cant hear them. I tried to edit the autoexec.bat manually, i installed all the different driver opportunities from philcomputerlab.com, all with the same outcome. I should mention, that i use a Soundblaster live! for win98 and the SB16 (2910 Model) for DOS. Might there be a problem by using both? I am no computer expert, and these DOS times are so long ago, but I will try to give you all the other information that you need to maybe help me out herer.
Thank you in advance for you help!
Reply 1 of 3, by Grzyb
Are the IFSD and APSD jumpers installed?
Kiełbasa smakuje najlepiej, gdy przysmażysz ją laserem!
Reply 2 of 3, by Sinchin
On IFSD is no jumper, on APSD the jumper sits on one pin. A jumper at JYEN sits on both pins.
Reply 3 of 3, by Sinchin
Alright, i put jumpers on IFSD and APSD, now everything seems to be working! Thank you very much for that. Thank you for that thought-provoking impulse, Grzyb!
