ISA IDE CARD SETUP
First post, by Soap
So recently gone right back to the family 486 where it all started for me.
I've had to set the system up again using the original recovery media but this ISA IDE card baffles me.
When the CDROM driver is attempting to load on startup I'm getting the error that no CD-ROM drive is connected. This is the original drive and it works fine on another system.
Does this IDE card require drivers which I'm under the impression it does, where would I find such drivers?
Cheers
EDIT
Data-Tech IDE-Connector + Audio & BNC, PCB-No. 400499-97 Rev. C FCC-ID: J8Y2183 Torisan CD-Wechsler, ISA 1996
Reply 1 of 12, by douglar
No, it does not require drivers. Simple IDE controllers like this do little more than attach your IDE device to the ISA bus. It is likely jumpered to be a secondary controller so you probably can’t boot from it with most standard BIOS without changing the jumpers.
The CDRom audio is just a passthrough connector from the cd rom drive to the external ports.
Is the CDrom driver configured correctly?
Reply 2 of 12, by Soap
douglar wrote on 2023-03-28, 11:53:
Secondary Channel in BIOS is set to NONE
CDROM is set to Master
FIles copied to CDRom folder on C:
VIDE-CDD.SYS
SHSUCDEX
Autoexec.bat line added
LH C:\CDROM\SHSUCDEX /D:CDROM /M:15 /E /S /L:D /V
Config.sys line added
DEVICEHIGH=C:\CDROM\VIDE-CDD.SYS /D:CDROM
I believe it is configured correctly??
Reply 3 of 12, by Disruptor
Well, what 486 board and what IDE controller do you use for the hard disk?
I guess your mainboard or the controller where you have connected the hard disk to has dual channel.
Thus your ISA controller and the present hardware is in conflict then.
Then you either need to remove that ISA controller from the board and to connect the CDROM to the present hardware or to disable secondary IDE channel in BIOS. However, using the present hardware is the best idea.
And you perhaps have a 4th IDE channel on the Sound Blaster too. 🤣!
Reply 4 of 12, by Soap
Disruptor wrote on 2023-03-28, 13:02:
Well, what 486 board and what IDE controller do you use for the hard disk? […]
Unfortunately the CDROM is not on the list of compatible devices for the AWE 32.
The motherboards secondary channel is disabled in the BIOS.
I'm quite stumped.
Reply 5 of 12, by Disruptor
There is no need that it's on the list of the AWE. It just is important that it has the same interface, like IDE. There exist several versions of the AWE which may have different CDROM interfaces.
Well, then it may work when you have the mentioned drivers copied to C:\CDROM
What happens when you connect the CDROM to the present controller and to enable it in BIOS?
Reply 6 of 12, by douglar
Is that isa card jumpered correctly for IRQ 15?
Reply 7 of 12, by Disruptor
douglar wrote on 2023-03-28, 13:35:
Is that isa card jumpered correctly of IRQ 15?
It does not look like that.
It should be one more away from the slot bracket.
Reply 8 of 12, by Soap
Disruptor wrote on 2023-03-28, 13:37:
My bad as I overlooked that.
Ok I set to irq of 15 on the jumpers for this card and the drive is now detected BUT I'm struggling with identifying the drive letter for the CDROM.
I type "d:\" and I get a return of invalid drive specification.
Any thoughts?
Reply 9 of 12, by Deksor
I see in your autoexec.bat that you typed
LH C:\CDROM\SHSUCDEX D:CDROM /M:15 /E /S /L:D /V
Shouldn't it be
You could also try to simplify it (for testing) to just C:\CDROM\SHSUCDX /D:CDROM /L:D
Reply 10 of 12, by Disruptor
Have you tried to use MSCDEX instead of SHSUCDEX?
MSCDEX /D:CDROM
Or try to use another handle than "CDROM", like "MSCD001"
Does this CDROM work on the present hardware?
Reply 11 of 12, by Soap
Deksor wrote on 2023-03-28, 16:36:
I see in your autoexec.bat that you typed LH C:\CDROM\SHSUCDEX D:CDROM /M:15 /E /S /L:D /V Shouldn't it be LH C:\CDROM\SHSUCDEX […]
Shouldn't it be
All is now good and I want to say thanks to all.
I went with a simplified option as proposed above and it worked first time.
Thanks all.
Reply 12 of 12, by Deksor
Glad I could help 😀
You're wasting some conventional memory though. If you encounter some memory errors later, you may want to go back to this and check if you cannot load it high again
