First post, by Nunoalex
Hi guys!
I dont know if this is the proper place to put my question...
I recently bought this bad boy and I need help identify the era of the case
Inside was a 486 VLB motherboard with a Intel 486 DX2 66 processor but the case is clearly from an older period
The case is from some obscure Belgium company called BMx and almost no information exists on the web about hem.
The case doesn't have a speed numeric LED but does have the turbo, reset a buttons/lights
The on/off switch is on the side with a big black switch that is connected directly into a massive power supply inside
Is this a XT case or is it a 286 or early 386 ?
Many thanx for the help
Reply 1 of 8, by mkarcher
That's the typical look of late 80s cases. Your case is a "deluxe" model, because you can open it without removing screws, just by pushing the buttons in the left and right side. No original IBM computer had that mechanism. Unless someone specically knows the model lineup of BMx, I don't think it's possible to tell whether it originally had a Turbo XT board (with Turbo at 8MHz or 10MHz), or a 286 board originally installed. It's also possible that BMx had both kinds of boards as option for that case. Obviously, this kind of case can't accomodate a full-size AT board (but a baby AT board will just fit) and has a more compact (but not necessarily less powerful) power supply than the original XT or AT, so it definitely didn't have one of the earliest 286 boards.
I'm excluding 386 for now, because the black back side was no longer common in the early 90s when there were 386(SX) boards that would fit the Baby AT form factor.
Note: What we know today as "AT boards" typically is baby AT or even smaller. "Full-size AT" as I wrote in the description refers to the size of the original IBM AT board (https://www.minuszerodegrees.net/misc/5170_mo … oard_type_1.jpg) which seems execessively large when compared to standard 486 boards.
Reply 2 of 8, by Nunoalex
mkarcher wrote on 2023-03-30, 07:47:
Thank you so much for your precious answer!
So... "deluxe" case huh? my oh my hehehehe
Inside is a relatively massive power supply by "A-Matik" rated at 150w
I notice now there is a sticker on the power supply saying "BMx 91/5 " ... so I guess it might be from 1991 witch would emply a late 286 maybe
And you are right... most "AT" motherboards are actually "baby-at" because a full AT board is HUGE ! 😀
Thank you
Reply 3 of 8, by the3dfxdude
This still is a generic case for baby AT. They could have stuck anything appropriate in from the time, whenever BMx actually sold the unit. I remember reading about these kinds of cases and being intrigued by the case design... around '90.
I guess it was a simple office computer? Even though it had vlb slots. Given that the drive covers are still intact, this never had a cdrom. The computers I built with vlb 94-95 were multimedia pcs by then, and therefore had cdroms in them. It's hard to say they really replaced the original board or not. What did the insides look like before they were removed? Did it have a hard drive in it?
Reply 4 of 8, by TheMobRules
I agree with mkarcher, it probably housed an XT or 286 in its time. From the stickers on the back you can tell it originally had a CGA/Monochrome card since it has LPT1 and DISP on the same slot. So I would say late '80s.
There is a slight difference in the mounting holes between XT and AT, but it's not an exact science. On XT boards (or older 286) the mounting holes are usually laid out in parallel lines (vertically), while in most AT style boards some of the holes are shifted slightly. If the case was intended for XT style hardware, it will probably only have fixed mounting points arranged in that style, while AT cases generally allow installing standoffs in different positions for supporting both layouts.
Reply 5 of 8, by Nunoalex
the3dfxdude wrote on 2023-03-30, 18:26:
Yeah, it was probably an office computer
no sound card, and on the hard drive only accounting software
it came though with a nice VLB video card, a Advance Logic ALG2201
the controller was ISA though
no matter it was just 25 euros 😀
Now I need to find it a nice old 286 motherboard to put in 😀
thanx
Reply 6 of 8, by jakethompson1
The most dated feature of the case is the key lock, no?
Reply 8 of 8, by BitWrangler
It was getting into the mid 90s by the time indy system builders quit using cases like that. In particular CAD specialists seem to stick with the "serious business" "desktop workstation" styling rather than the frivolity of these upstart mini towers with gaudy garish Mhz displays. Even seen P60/66 systems built new in that style, but by then I don't know if it was fresh manufactured or old stock.
