First post, by AlessandroB
As many know I only collect IBM desktops and I have practically one for each CPU class (5150, PS/2, PS/1, DX4, P60, P200, P4) I only miss slot1 which deals with PentiumII/III cpu because I'm focused on systems up to Pentium200 (the P4 I need only in case of need as brute force). Looking at the availability online I realize more and more that (especially the old one) are increasingly rare and expensive. So I was thinking about using my computers when I want to test something in the correct Period with the correct CPUs, but if I want to finish DuneII or Doom, or X-Wing not to have my 386 and 486 running for hours and hours...
So it occurred to me to get myself a (always desktop and always IBM of course) Pentium II/III so as to have a very robust machine, still cheap to buy that could support the gaming load (mainly DOS and early Win98) for hours and hours, a computer for daily use in retro gaming. Not to mention that it would complete my collection as PII/PIII...
I found a nice IBM PC300GL with the 66/100Mhz Bus (not all have it) but it is the version without AGP slots (but it still has the ISA slots which in the desktop socket 370 versions have been eliminated).
my only little doubt is that not having the AGP slot it is too limited... I state that it will be used mainly in DOS and windows98 in strategy games (C&C and similar) I don't like games like Quake or Unreal. onboard has a S3 Trio 3D.
As always, tnks.
Reply 1 of 16, by TrashPanda
If you have no intention of running demanding 3D games then itll be just fine, in fact even for 3D itll be ok until you hit the more demanding DX6/7 titles that take advantage of the higher AGP speeds and Memory handling. Pretty much all early AGP GPUs treated the AGP bus as a glorified 66Mhz PCI slot and the Voodoo AGP cards are well known for not even caring about AGP features or speeds.
So I wouldn't worry about it too much for DOS and basic Win98 stuff, just grab the nicest PCI card you have and enjoy it.
Reply 2 of 16, by RandomStranger
For those type of games, i don't think it's particularly limiting. The Trio3D is not a good 3D accelerator, but most RTS until about 1998-1999 are still 2D. I'd expect issues with something like Homeworld, and other late era 3D games, but you can always get a half-decent PCI graphics card like a Matrox G450 or Radeon 7000.
Reply 3 of 16, by chinny22
This is one of the benefits of been a cultured RTS player rather then part of the 3D-shooter horde. We are far less demanding 😉
Early windows RTS's the S3 will be fine. 3d games like Empire Earth may be pushing it a bit.
Something like a ATI Rage, or Matrox G200 - 550 can be had for not much and offer performance roughly around the TNT/TNT mark.
In dos the S3 is about as good as it gets, this is where ATI and Matrox would be a downgrade compatibility wise. However dos strategy games don't feature on the compatibility list so this may not be an issue either. (I've never noticed the Warcraft noise issue in this table)
https://gona.mactar.hu/DOS_TESTS/
Reply 5 of 16, by bogdanpaulb
AlessandroB wrote on 2023-04-05, 07:23:
As always, tnks.
For that only, the onboard video card is more then enough.
Reply 7 of 16, by H3nrik V!
Am I totally off, if I recall that a real draw back of an on-board graphics chip was not only its abysmal performance, compared to GeForce etc., but also that it really crippled the memory bandwidth of the CPU as well, making it sub-par performance wise?
Reply 8 of 16, by bogdanpaulb
I haven't seen until now a onboard s3 trio/virge/trio 3d which shares ram with the system memory and doesn't have it's own vram, but maybe i'm wrong. Anyways, if this is the motherboard, the integrated video chip has it's own vram and can be upgraded also. It'a 'standard' trio 3d soldered directly to the board. For dos and win98 2d games trio 3d should be good enough, it's super compatible with dos and for 2d in win98 it is a very good performer. For 3d, which he said he didn't care about, a pci Voodoo or a Geforce can be used. Also i see the space to populate a agp slot if you have the parts and the knowledge 😁.
    430.7 KiB
Reply 9 of 16, by H3nrik V!
bogdanpaulb wrote on 2023-04-05, 16:03:
Right, I remember now. It was the chipsets which had integrated "gpu" that suffered from sharing memory ... 😀
Reply 10 of 16, by acl
H3nrik V! wrote on 2023-04-05, 15:09:
I think you you're right.
And that was the primary benefit of dual channel with nForce AthlonXP.
The Athlon itself could not benefit from more bandwidth (due to its own limitations). The dual channel was said to improve the performance by only 4-6% with the doubled bandwidth. But when coupled with an integrated GeForce MX the GPU was not competing with the CPU.
(Not sure, but this may also improve performances when using GPUs with not enough memory that needs to use the system RAM)
Reply 11 of 16, by AlessandroB
yes, it's exactly this one.
Reply 12 of 16, by smtkr
You could always get a Slot 1 Pentium II IBM Aptiva system with the integrated 3D Rage Pro chipset. Those were extremely common back in 1998 and should be easy enough to find. From what I remember, the integrated rage pro chipset had really poor performance (likely related to the state of ATI drivers at the time), but then you could just put in a faster PCI accelerator if you're not satisfied.
In terms of AGP vs. PCI, I don't think it's a big deal. It basically just limits your ability to run advanced chipsets from 2000 and later. Prior to that, most chipsets had both AGP and PCI versions, and performance between the PCI and AGP variants wasn't significant, IMO.
Reply 13 of 16, by BitWrangler
Yah if you're patient, you should find something worth running for $50 or better in PCI , MX4000, Rage 128Pro, Radeon PCI, even the maligned FX5200 won't be bad in that. (Until you expect it to perform like a DX9 system with decent card and twice or three times the CPU of course) Maybe even score a banshee, or mis-described V3 2000.
Reply 14 of 16, by Mamba
Or you can get a pex8112 pci to pcie bridge, grab any hd5450 low profile for 10€ and be happy with anything you want.
Even FullHD, h.264 movies (with mpc-be) if you plan to use Win XP.
Reply 15 of 16, by AlexZ
PIII without AGP is only good for early Windows 98 games. I would not recommend it. PIII with a good AGP 3d card works flawlessly for games up to 2001. As an alternative to PIII you can use Athlon on KT133. Don't waste your money.
Pentium III 900E, ECS P6BXT-A+, 384MB RAM, NVIDIA GeForce FX 5600 128MB, Voodoo 2 12MB, 80GB HDD, Yamaha SM718 ISA, 19" AOC 9GlrA
Athlon 64 3400+, MSI K8T Neo V, 1GB RAM, NVIDIA GeForce 7600GT 512MB, 250GB HDD, Sound Blaster Audigy 2 ZS
Reply 16 of 16, by AlessandroB
AlexZ wrote on 2023-04-07, 09:01:
this P3 is not compatible with coppermine, is just to use it instead of 486/PentiumMMX. In the IBM line the only P3 models with ISA is restricter to Slot1 with 2.0v of cpu core. but is not a problem the system speed, i not need to use it until 2000…
