First post, by GN323
Hi All,
I've just put together a Windows 98SE gaming rig(ish):
Intel Celeron Coppermine 996MHz
Gainward NVidia Geforce2 MX400 64MB
256MB PC-100 RAM
Sound Blaster Live! SB0220
Maxtor DiamondMax 80GB HDD
Gigabyte GA-60MM7E 1.1 Mobo
Based on benchmarks i've seen online, this system should be running things like Unreal and Morrowind post 30FPS at 640x480x32, yet I get 5-15 at most.
I've tried various GPU drivers:
Detonator 3 version 45.23
Forceware version 81.98
Gainward drivers that came with the GPU (idk what version they were)
Honestly not sure at this point why the system isn't running games better (unless my expectations for this config are too high?) so I was wondering of anyone on here had some torubleshooting solutions?
Reply 1 of 16, by bloodem
Unreal and Morrowind are two very different games with very different requirements.
Unreal should run at 30+ FPS on your PC (averages should be more around 50 - 60 FPS).
Morrowind, on the other hand... yeah, you can probably hope to hit a ~ 15 FPS average. 😀 This game really needs something like a GeForce FX 5700 Ultra (notice the "Ultra", it's very important 😁 ) or faster.
Having said that, my advice is to also try older drivers (for games released before 2001). Detonator 7.76 works very well with pretty much all period correct games.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 2 of 16, by GN323
bloodem wrote on 2023-04-07, 19:14:
Unreal and Morrowind are two very different games with very different requirements. […]
Cheers for that advice, I should've known the Bethesda title would require more power (besides being newer). Have you got a good link for the 7.76 driver? I've seen mention of it in threads on here before but the copy on VOGONS drivers never worked, and seems to be incomplete. Oldest Detonator drivers I can find is the one I tried.
Reply 3 of 16, by AlexZ
You haven't stated the board you're using. Intel 440BX or Via 694X (T) is necessary for decent performance. Swap the Celeron for a PIII 1Ghz or 900E as they are superior.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 4 of 16, by Repo Man11
GN323 wrote on 2023-04-07, 20:17:
The 7.76 driver on Vogons is fine, but it doesn't work the way that later Nvidia driver installers do. Here's a tutorial that shows how to manually install a driver with Windows 98 - this is the same procedure you'll need to use to install the 7.76 Nvidia driver.
https://www.youtube.com/watch?v=QGxknBU0fMo
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
Reply 5 of 16, by rasz_pl
https://www.youtube.com/watch?v=EC4H94-O8fI
one generation too slow for morrowind
Reply 6 of 16, by tomcattech
As others have said... motherboard?
Get rid of the Celeron.
Also, I've never been a fan of that mx400 card....
I either fix it or break it permanently... there is no try.
Reply 7 of 16, by smtkr
Morrowind came out about the same time as the Geforce 4 and lots of people played it on Geforce 4s with all of settings cranked. But given that it came out with the Geforce 4, you have to believe the developer expected people to play it on lesser hardware with some settings turned down.
Reply 8 of 16, by bloodem
smtkr wrote on 2023-04-08, 05:38:
Yeah, well, it really depends on your expectations. If you want a consistent 60 FPS at higher resolutions, you're looking at high-end 2003/2004+ hardware. When it came out I actually played it on an Athlon XP 2200+ with a GeForce 3 Ti 200. It was... OK/"playable", for the time (15 - 25 FPS at 800 x 600), but it was far from playable by more modern standards. Of course, something like a Radeon 9700PRO (also from 2002), or a high-end GeForce FX would be enough for an enjoyable experience (but still NOT perfect at higher resolutions). In 2023, I for one would not play it on anything slower than a Radeon X800/X850 or GeForce 6800. I suffered enough back in the day... 😁
Then again, if I have a nostalgic moment, I might go for the "kill-me-now-I-hate-this-performance" approach. 😁
Reply 9 of 16, by Sombrero
I tried Morrowind couple weeks ago on my P4 3.4GHz / 6800 GT system and it ran like crap in the starting town all maxed out at 1024x768.
I guess I could have gotten ok framerate by lowering draw distance but the game crashed during character creation and I decided to wait till OpenMW gets to 1.0 🤣
Reply 10 of 16, by GN323
AlexZ wrote on 2023-04-07, 20:19:
Was planning on doing a CPU upgrade, as for the mobo, it's a Gigabyte GA-6OMM7E socket 370 board.
Reply 11 of 16, by GN323
Repo Man11 wrote on 2023-04-07, 20:28:
Cheers for this, I'll try it out today.
Reply 12 of 16, by rasz_pl
GN323 wrote on 2023-04-08, 09:04:
you could even run Tualatins on this board with some mods, but forget upgrading CPU just to play Morrowind. Morrowind simply wont happen in a playable fashion on this generation of hardware.
As for cutting details to play on slow systems - Pixelmusement did a video covering Oblivion 😀 https://www.youtube.com/watch?v=o87ttqRQB58 its not something you would want to do.
Reply 13 of 16, by GN323
rasz_pl wrote on 2023-04-08, 19:51:
Yeah morrowinds out the window at this point 🤣. More aiming for unreal and half life.
Reply 14 of 16, by AlexZ
Unreal and Half-Life run great on my PIII 900E, including other titles such as Soldier of Fortune, Return to Castle Wolfenstein.
Reply 15 of 16, by smtkr
Just out of curiosity, I installed Morrowind with the latest Bloodmoon patch on my current testbench setup and it's surprisingly playable at 1024x768.
Windows 98SE
1.13GHz Pentium III-S
512MB CAS 2 PC133
Geforce 2 GTS 64MB
The water looks terrible and dull since we don't have shaders. But you could play through it on this setup and have a good time if you didn't know some visuals are missing.
I still wouldn't recommend it, since we're 20 years after the fact and you can just buy better hardware to play it (or better yet, play it on a modern system).
Reply 16 of 16, by GN323
smtkr wrote on 2023-04-11, 01:17:
Just out of curiosity, I installed Morrowind with the latest Bloodmoon patch on my current testbench setup and it's surprisingly […]
Windows 98SE
512MB CAS 2 PC133
Geforce 2 GTS 64MB
Yeah, I should have known Morrowind was a stretch, but i'm still pretty new to this hobby. I'll likely be building an XP rig in the near future, so i'll save it for that.
