First post, by Jackhead
I really confused about the search results people say " I have Fake cache". I hope someone can help me clear this.
First at all when i search for fake cache any time i got only the info that cachechk say there is no L2 Cache.
And to be honest i testet now 3 different cache sets and that cachechk tool tells me any time different stuff.
SO lets start with my first question.
Fake cache is detected as real chache on bios? Means i can activate L2. Boot screen shows up the correct amount. System boots fine , but cachechk say its "maybe" fake chache than it is?
Or does fake cache dont even show up on boot, and system dont boot when L2 is activated?
I test 256KB 4 chips and 2x 1MB sets. Some bench tools say i have 128kb some say 256kb cachechk say 0..
Than i start testing my read/write speeds with and without L2 active. And i got different results. Of corse faster with L2.
To be honest im not sure what to trust...
Reply 1 of 16, by Hezus
From what I know, fake chips on some 486 boards were just dummy chips: a DIP package that had no function inside at all. They were there to trick people to think there was L2 on the board.
The other kind of fake chip is where the reseller puts a new coating on the chip with a new print. It's often a cheap unrelated part that they try to sell as a more popular chip for profit. Your chip might not work at all, in such a case. Or, it is a cache chip but of a lower capacity than was advertised.
Some BIOS could report the cache on boot, even tho you have none installed. It then just echoes whatever you set in BIOS.
Speedsys should be a quite reliable tool to verify your memory.
Visit my YT Channel!
Reply 2 of 16, by paradigital
Hezus wrote on 2023-04-13, 21:14:
Yep, like on my PCChips M919.
And the traces on the back, which are hilarious:
Fortunately I own a cache module for it, so mine actually has cache.
Reply 3 of 16, by Jackhead
So here my speedsys membench. It says i have 1MB, cachechk say i have nothing.
That means cachechk cant read out my hardware correctly?
The attachment IMG_4153.JPG is no longer available
Reply 4 of 16, by CoffeeOne
Jackhead wrote on 2023-04-13, 21:34:
Hi.
Sorry, but 🤣.
You use the Asus SV2GX4 board, that board does not report wrong cache sizes.
So when the boards shows 1MB L2, you have 1 MB L2.
So cachechk is just wrong. speedsys clearly shows that it is real 1MB L2 cache, too.
Remark:
You seem to have slightly mis-configured somethine, because your values are not on the highest level.
See here:
Re: Avance Logic ALG2228 VLB
EDIT: To be more precise, you L2 cache is NOT running on 2-1-1-1 read and 2T write. Do you have 2-2-2-2 read?
Reply 5 of 16, by mkarcher
Your RAM is too fast (or your L2 is too slow, depends on the point of view), so the speed difference between cached reads and non-cached reads is too low for cachechk to pick it up. Try adding RAM wait states in the setup, and see whether cachechk then recognizes the correct amount of cache.
Reply 6 of 16, by Jackhead
Thanks guys! Here my settings, maybe you see what i can improve here.
So I need go up WS, or cache w/r. I have 15ns cache . And Rams are 60ns.
The attachment IMG_4154.JPG is no longer available
Reply 7 of 16, by CoffeeOne
Jackhead wrote on 2023-04-13, 21:51:
Cache Burst Read should be 1T!
Also change Slow Refresh to Enabled. Slowly refreshing the DRAM means a faster performance. But minor improvement.
Cache Burst Read is important.
EDIT:
Interesting would be also setting local bus values to T2 and Transparent.
You have to check, if the computer is still stable then. No guarantee 😁
But you could beat my ARK 1000VL 27000kB/s value in speedsys. Maybe.
Reply 8 of 16, by Jackhead
CoffeeOne wrote on 2023-04-13, 21:56:
Cache Burst Read should be 1T! […]
Here we go:
The attachment IMG_4155.JPG is no longer available
Reply 9 of 16, by CoffeeOne
Jackhead wrote on 2023-04-13, 22:01:
Here we go:
Great.
Now try T2 and Transparent. Graphics speed would be higher. Keep in mind, that you have already good graphics speed.
Reply 10 of 16, by Jackhead
When i set Transparent system dont boot. Hold after memcheck. With T2 only i see no difference on bandwidth
Reply 11 of 16, by CoffeeOne
Jackhead wrote on 2023-04-13, 22:11:
Yay, then keep T3 and Synchronize.
Still the ET4000W32p is pretty fast.
You could post values from Phil's Benchmark Suite:
Quake, Doom (fast PCs) and others.
Your PC is now competitive 😉
Reply 12 of 16, by Jackhead
For now im pretty happy that "fake" nonsense is cleared.
Btw i ordered the chips here from amazon, pretty cheap. Just tryed it and looks it was worth 😀 . Maybe this help someone else.
Thanks everyone!
https://www.amazon.de/IS61C1024-15N-IS61C1024 … 81424722&sr=8-1
Reply 13 of 16, by rasz_pl
CoffeeOne wrote on 2023-04-13, 21:40:
Do I see it right that read speed goes from 15MB/s uncached (386 boards do better) to ~30MB/s? How does it look if cache is disabled completely?
Reply 14 of 16, by CoffeeOne
rasz_pl wrote on 2023-04-14, 02:49:
No, you don't see it right.
Reply 15 of 16, by rasz_pl
CoffeeOne wrote on 2023-04-14, 04:47:
Yes, I was looking at moving 🙁 . Its ~45 to ~67, weird that cachechk doesnt pick it up
Reply 16 of 16, by mkarcher
rasz_pl wrote on 2023-04-14, 10:53:
When the OP stated that cachechk doesn't pick it up, L2 timings were bad (2-2-2-2 instead of 2-1-1-1), and it went from 45 to 53, which is a smaller difference than what you see now.
