Standard DOS CPU usage is constant full usage AFAIK. Meaning it's not gonna vary with application/game load as they don't typically issue idling instructions (there is a TSR that can modify that though). In this case I assume you just want to make sure the CPU is doing fine with your cooling solution? So, what are you using? Pentium MMX requires a small heat-sink and a fan IIRC.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, FDDx3
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
