CD-Rom changer question?
First post, by funcle
I have an IDE NEC 4 cdrom changer and want all the drives available to DOS. Can't seem to use more than the first drive available. Is this even possible or is a specialized driver needed?
Reply 1 of 4, by Disruptor
Is yours a SCSI or IDE/ATAPI one?
If it is SCSI, check whether LUN support is enabled (on that device ID).
Which driver do you use?
Reply 2 of 4, by funcle
This is an IDE drive and using mscdex.exe and videccd.sys.
Reply 3 of 4, by Disruptor
I'm not sure whether this driver supports CD changers.
I guess you need a different driver, but I can't recommend any driver that supports IDE/ATAPI changers.
