First post, by pico1180
Hello there everyone,
I had a resister disintegrate on a motherboard. Nothing left to identify it. Even if I knew how I couldn't because nothing is left of it. Please see pictures indicating the resister I need to replace. I don't know what a suitable replacement would be.
    122.57 KiB
    153.34 KiB
Reply 1 of 7, by weedeewee
looks like a diode
likely is a diode.
even the marking indicates it as a diode. D6 .
Do not ask Why !
Reply 3 of 7, by weedeewee
pico1180 wrote on 2023-04-18, 17:41:
weedeewee wrote on 2023-04-18, 17:40:
looks like a diode
likely is a diode.
that makes since because it doesn't look like any resistor I can find.
That's likely because it isn't a resistor 😀
and I can't tell from the photos if it's actually burnt or not.
looks like a typical 1N4148 diode though might be something different.
Do not ask Why !
Reply 4 of 7, by pico1180
weedeewee wrote on 2023-04-18, 17:43:
That's likely because it isn't a resistor :-) and I can't tell from the photos if it's actually burnt or not. looks like a typi […]
looks like a diode
likely is a diode.
those are just example photos for the diode that should be there. the one being replaced is completely gone.
if i put a 1N4148 diode in and it isn't the right one, do i risk anything?
Reply 5 of 7, by weedeewee
Diodes have a 'polarity', so you have to put it in the correct way.
I guess worst that can happen is it blows up again.
Do not ask Why !
Reply 6 of 7, by bogdanpaulb
Diode, by the way it looks and the marking (drawing that's visible) underneath. There seem to be a 48 on it in the first picture, so it could be a :https://en.wikipedia.org/wiki/1N4148_signal_diode. Mind the polarity (cathode, the black strip on the right side).
