First post, by anetanel
I got an ISA TV Card, and I'm unable to find any documentation for it.
It seems like a passive card, meaning that it gets only power from the ISA slot. It has VGA pass-through connectors, which works.
I guess that it is operated by some kind of IR remote that will switch it from "Computer Mode" to "TV Mode".
There is an IR port on the bracket, but I don't have the IR sensor.
Tried looking the FCC ID, and googling various parts and labels I found on it but could not find any relevant info:
FCC ID: IJEMT-3
MT-3Z
ESSEX Monitor CO., LTD.
Help 😀
Reply 1 of 9, by dormcat
The address raised my attention; the location is now an unrelated packaging company, but "Essex Monitor" was also known as "Proview" or 唯冠 and was quite active in digital TV business back in mid-2000's but declined a decade later.
The brand/company is still alive in mainland China, targeting budget market (sub-US$100/RMB¥500) of LCD monitors.
Not sure if those info helps though. 😅
Reply 2 of 9, by anetanel
Thanks.
Eventualy I found the fcc "report" for this device, and found out too that it was made by Proview.
Sadly there is no substantial information in the fcc site. Unlike other products where I could find pictures or even schematics.
The trail went cold again 😝
Reply 3 of 9, by jmarsh
Strange, it looks like it's connected to the MEMR and MEMW lines on the bus but that doesn't make much sense when it's not connected to any of the address or data lines.
Reply 4 of 9, by anetanel
jmarsh wrote on 2023-04-20, 20:13:
Ummm As far as I can tell, the connected pins are B1, B3, B7, B9, B10, B29, B31, D16, D18. All are power pins...
Reply 5 of 9, by anetanel
OK, this is hilarious.
I rummaged through my shelves and found a TV Card in a box, and.. it is the same card that I was looking for information for!
I had another one all that time, complete in box with the manual, remote and all the cables 🤦🏻
I'm attaching the manual and some photos for future reference.
The attachment עותק של IMG_8375.JPG is no longer available
The attachment עותק של IMG_8376.JPG is no longer available
The attachment IMG_8377.jpg is no longer available
The attachment IMG_8378.jpg is no longer available
The attachment IMG_8379.jpg is no longer available
Reply 6 of 9, by anetanel
The attachment IMG_8380.jpg is no longer available
The attachment IMG_8381.jpg is no longer available
The attachment IMG_8382.jpg is no longer available
The attachment IMG_8383.jpg is no longer available
Reply 7 of 9, by dormcat
"No software required"
Hmm, this is interesting. I wonder what makes it run under DOS or Windows (3.1?).
And it's funny to see "PC-TV CONVERTER will Auto detect and display PAL NTSC standard" taped out. 😅
Reply 8 of 9, by rasz_pl
dormcat wrote on 2023-05-07, 19:31:
nothing, its an external standalone tuner card .. taken out of its box and shoved into ISA slot to provide power 😀
https://github.com/raszpl/440BX Reference Design adapted to Kicad
Reply 9 of 9, by dormcat
rasz_pl wrote on 2023-05-08, 06:02:
Wait, so it's just a tuner that powered by an ISA slot and uses the monitor to output TV signal but has no communication with the computer for functions like recording, frame grabbing, etc.? Well that explains why the system requirement is so low; video capturing back then required much better hardware.
