First post, by rick12373
 - Oldbie
I have a fresh install of Windows 98. I ran the setup for the Sound Blaster CT1770 in Windows which worked. I restart in DOS mode and try to run the SBBASIC.EXE to set the sound card up for DOS and it says it can't install while running Windows. Is there a different way I should be doing this?
Thanks,
486 DX4-100 (overdrive)
16MB 72-pin SIMM RAM (2x8MB)
1MB Diamond Speedstar Pro VLB video card
SB 16 Value CT2770
AOpen VI15G Socket 3 Motherboard
HDD/FDD VLB controller card
