First post, by Jackhead
- Member
I build another Windows XP system for me based on the X58 chipset.
My goal is running a Voodoo 5 6000 PCI (rebuild of corse..) on a PCI-X Slot with 66MHz as i can get same speed as AGP with the option using "newer" hardware.
I still dont have the voodoo, and i dont even know if this work out at the end. Anyway when not i use it as very nice XP build..
So after some research i choose the Asus Workstation board because it has PCI-X Slots with 66MHz.
The 990x is really nice CPU. Managed to run with stock voltage @ 4,5Ghz prime stable under water max 65*C.
I also cooled the chipset active with a small noctua.
Here the components i used:
MB: Asus P6T WS Pro REV 2.0 socket 1366 X58
CPU: E8600 - 2core @ 4,5Ghz Aquacomputer custom water cooled with 360er
RAM: Kingston HyperX 2x 1GB 1066
GPU: Strange God Voodoo 5 6000 PCI 256MB
SPU: Creative Soundblaster Audigy 2 ZS
SSD: Samsung 970 Evo 500GB @ AHCI ICH10R
OS: Windows 98SE Patched custom X58 Chipset driver
PSU: be quiet! SP9 600W CM
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - AMD A5x86 X5 ADZ 133MHz @160MHz - 64MB RAM - CT2230 - GUS ACE - MPU-401 AT - ET4000W32P
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI @ 66MHz PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
