First post, by Gahhhrrrlic
With regards to a P133 machine, Rage II, Win95, I'm trying to get Carmageddon to work in hardware 3d. All the videos show it looking pretty good but when I install and run it (I am indeed running the W95 installer), it looks like it's 320x240 at best and no hardware processing to speak of. Horrible color banding, blockiness, aliasing, you name it. Looks like Wolf3D basically.
Is there some sort of hardware setup I have to go through or an INI file I have to edit or a switch I need to run through the command line? Just looking to understand how/why this is happening and what I'm supposed to do to set the render and resolution.
Thanks.
https://youtu.be/BlBH5VvPXKU
Reply 1 of 8, by Zup
Carmageddon had options to run at 640x480 and, more important, 3Dfx support. Maybe you're looking at the 3Dfx version.
I'm selling some stuff!
Reply 2 of 8, by Gmlb256
Gahhhrrrlic wrote on 2023-04-22, 20:26:
No, the Windows version (if that's what you mean) doesn't support any kind of 3D hardware acceleration. It is only available for 3dfx hardware with the DOS version after installing a patch that can be found on the following site: https://soggi.org/misc/3dfx-voodoo-game-patches.htm
You can run Carmageddon at 640x480 in software rendering with the "-hires" command line switch but it will be slower.
Reply 3 of 8, by Gahhhrrrlic
err... but I found this game specifically on account that it uses BRender, one of the few APIs that ATi specifically accelerates. So the RageII does nothing in this game? It's all running over the CPU?
Reply 4 of 8, by Pierre32
I've never heard of BRender until now, so this was an interesting rabbit hole.
Background: https://wiki.cwaboard.co.uk/wiki/BRender#BRen … and_Carmageddon
According to Foone:
BRender is at its core a software 3D Renderer, but it developed a sort of plugin architecture that let you hook in different 3D renderers, customized per 3D chip.
So like you'd have a Matrox Mystique, a 3DFX driver, an ATI Rage driver, and so on.
https://twitter.com/Foone/status/1307743559563407361
So I guess when you're seeing the software rendering, you're seeing BRender in action?
These two sources show Carmageddon in the BRender context but I'm sure what we're seeing is BRender + Glide:
The attachment carmageddon.png is no longer available
https://blazingrender.net/
The attachment Screenshot 2023-04-23 125304.png is no longer available
https://www.youtube.com/watch?v=TthBMp7pQdE
Reply 5 of 8, by Gahhhrrrlic
So does this mean it will run over the CPU if it doesn't detect anything but if it finds a compatible card it'll run in hardware? And only in the DOS version apparently?
Reply 6 of 8, by feda
Gahhhrrrlic wrote on 2023-04-23, 05:39:
Carma 1 for DOS supports CPU-based software rendering or 3dfx Voodoo (only with the patch). The Windows version only supports software rendering. Nothing else is supported. Your Rage card is useless here.
Reply 7 of 8, by Gahhhrrrlic
Well that sucks. If the card was designed to interpret the function calls and the game is using them anyway, why the hell not allow the card to accelerate them?
Reply 8 of 8, by Pierre32
Because they're not there. Per Foone's description, BRender is a software renderer and separate drivers still have to be implemented for each 3D API. They only released one for 3DFX.
Complaints here https://www.stainlessgames.com/contact 😁
