First post, by Sake
This may be a problem with WinXP, but since I only notice it with DOSBox, someone of you might have come across it as well.
It seems that no process (i.e. DOSBox) is allowed to use more than 50% of the processor. When I use fewer cycles less CPU is used but at about 13000 it hits 50% and raises no more. The total CPU load is only 58% so there are no other programs that steal calculating power. I already tried to set the process to a higher priority, but that didnt change anything.
My computer is a Pentium IV 2800MHz with 1Gb of Memory.
Anybody anyidea?
