First post, by kalanneni
Hello everyone,
I've recently purchased a retro PC:
Abit BH7-E motherboard
Celeron 2 Ghz
ATI Radeon 9600XT
Kingmax 1 Gb 400 DDR RAM
Everything is working fine, Win Xp Sp3 is running without problems. Then I wanted some improvement, and ordered a Pentium 4 2.4/1Mb/533 CPU, in allegedly working condition. I swapped the CPU-s and powered on the PC, but there was no POST (every moving part started to work, but no speaker beep and VGA signal). Swapped back to the Celeron, and everything working fine again.
I changed the CMOS battery and done a CMOS reset but nothing happened.
The CPU is officially supported by the motherboard. What could be the problem? (Mobo specifications says using DDR 400 means overclocked status, maybe I need to downgrade the RAM for using 533 FSB CPU?)
Thank your for your help!
Win98SE PC - ASUS P3BF, PIII 500, 256 Mb RAM, V3 2000, SB Live
WinXP PC - ABIT BH7, Pentium 4 2.4, 1 GB RAM, ATI Radeon 9600XT
Reply 1 of 7, by weedeewee
dead cpu.
as in dead Pentium 4 2.4 CPU
or if you want a more hopeful reply,
It might just be that your motherboard needs a recap, due to the new p4-2.4 cpu requiring more power than the older celeron, which causes it to not boot with your current mainboard.
Do not ask Why !
Reply 2 of 7, by PcBytes
Could be dead CPU. I have a bunch of 2.4 and 2.8 chips here that are doornail levels of dead.
Reply 3 of 7, by paradigital
You say you ordered a 533MHz part, but is that what arrived?
Reply 4 of 7, by kalanneni
weedeewee wrote on 2023-04-23, 11:56:
dead cpu. […]
dead cpu.
Okay, so as the cheapest solution I might get another P4 CPU (I got this for circa 9$) to check if the mobo is broken or not. Recapping could be more expensive then the whole mobo 😒
Or I accept my fate and use the Celeron 😀
Reply 5 of 7, by kalanneni
paradigital wrote on 2023-04-23, 16:47:
Totally, I checked the CPUs top.
Reply 6 of 7, by Karbist
If it has 1MB cache then it's a Prescott cpu which may not be compatible with this motherboard.
I checked the latest bios for this board and it only has cpu micro codes for northwood cpus:
The attachment cpuid.jpg is no longer available
you can pick one of the northwood cpus listed here: https://www.cpu-world.com/CPUs/Pentium_4/TYPE … 0Northwood.html
they have 512kb cache and the 3Ghz one ( SL6WK) has a reasonable price.
Reply 7 of 7, by kalanneni
Karbist wrote on 2023-04-24, 18:45:
If it has 1MB cache then it's a Prescott cpu which may not be compatible with this motherboard. I checked the latest bios for t […]
Wow. Thank you for this thorough answer. I'll check one of these CPUs 😀
