First post, by deepthaw
I’ve noticed that I use WSS for digital sound on my YMF715E-S that the volume on GM via my waveblaster card seems to drop substantially. When I use SBPro mode it works fine on the same waveblaster setup. Is there something in the SETUPSA mixer settings I need to play with? The channels under WSS don’t seem to labeled as well as they could.
(I’ve already done the SB level at 1 setting so that volume control in sbpro mode works right.)
