First post, by jsedano
Hello,
I have this old beauty around the house. I have attached a SLIP cable to COM1, so now I have Internet! But then the mouse is not available (because the mouse is serial). The "BIOS" (Compaq setup) identifies two serial ports: COM1 (which is the DB9 available from the back of the computer) and COM2/modem... which is the internal "expansion" slot. So I was guessing that... with a bit of luck, the expansion slot is just a COM2 with a board expansion connector instead of a DB9.
Then, the questions are:
Has anybody played with it?
Does anybody have a specification of the pinout of the internal expansion port?
Any other idea?
Regards,
Javi
