First post, by Jo22
- l33t++
Hello everyone,
I've got a copy of an old VGA driver diskette, which was part of my father's diskette collection.
It has similar content to Elianda's fine driver set found at Vogonsdrivers:
http://vogonsdrivers.com/getfile.php?fileid=87&menustate=0
However, the ZIP files on my father's diskette seem to be newer, dated 1992 rather than 1990/1991.
But that's not so important, maybe, since the files inside them have same date sometimes.
There are also other differences. The 8514/A emulator is missing on my father's diskette.
On the other hand, the supplied SVADI driver is more recent and has additional 1280x1024 and 1024x768 resolutions (render/display)
There's also a newer VBE TSR, which supports both OTI-067 and OTI-077.
(Not so important, since there were big VBE driver collections being published on shareware CDs, see example).
Here's what the readme says :
Driver version 2.2 requires the BIOS version to be 1.05 or higher. Driver diskettes contain the following driver files : […]
Driver diskettes contain the following driver files :1. README.DOC This file that you are reading
2. PKUNZIP.EXE Extraction utility
3. INSTALL.EXE Utility to extract driver files
4. AUTOCAD/AUTOSHADE V2.62
DSVGA.EXE 800 X 600 16 colors
5. AUTOCAD RELEASE 9/10/11 AND AUTOSHADE V1.1 & 2.0 AND AUTOSKETCH 3.0
SVADI.EXE Super VGA ADI real mode driver
SVADIDL.EXE Display List Driver for real mode
RCPSVADI.EXP Super VGA ADI protected mode driver with display list
SVADI.CFG Driver's configuration data
SVCONFIG.EXE Configuration utility for SVADI.EXE
SVADI.DOC Documentation fileDisplay resolutions and colors:
640 X 480 16 colors
640 X 480 256 colors
800 X 600 16 colors
800 x 600 256 colors
1024 X 768 4 colors
1024 X 768 16 colors
1024 X 768 256 colors
768 X 1024 16 colors
1280 X 1024 16 colorsRendering resolutions:
320 X 200 256 colors
640 X 400 32K colors
640 X 480 32K colors
800 X 600 256 colors
1024 X 768 256 colors6. CADVANCE V4.0 & V4.01
CADV800.DRV 800 X 600 16 colors
CADV1024.DRV 1024 X 768 16 colors
CADV768.DRV 768 X 1024 16 colors7. FRAMEWORK II FRAMEWORK III TEXT RESOLUTION GRAPHICS RESOLUTION
FW20.SC FW30.SC 132 X 60 640X480 16 colors
FW21.SC FW31.SC 132 X 60 800X600 16 colors
FW22.SC FW32.SC 132 X 25 640X480 16 colors
FW23.SC FW33.SC 132 X 25 800X600 16 colors
FW24.SC FW34.SC 132 X 43 640X480 16 colors
FW25.SC FW35.SC 132 X 43 800X600 16 colors8. GEM/3 V3.1
GEM3.BAT GEM/3 Installation file for GEM/3
GEN4GEM1.EXE
GEN4GEM2.EXE
G1024C16.311 Text file required by the Installation file
GOAK800.311 800 X 600 16 colors
G16C768.311 768 X 1024 16 colors
G4C1024.311 1024 X 768 4 colors
GOAK1024.311 1024 X 768 16 colors9. LOTUS V2.0X
TD132X25.DRV 132 X 25 Text resolution
TD132X43.DRV 132 X 43 Text resolution
OAK640.DRV 640 X 480 Graphic resolution
OAK800.DRV 800 X 600 Graphic resolution10. LOTUS V2.2
OAK13225.DRV 132 X 25 Text resolution
OAK13243.DRV 132 X 43 Text resolution
OAK13260.DRV 132 X 60 Text resolution
OAK80016.DRV 800 X 600 16 colors
OAK10244.DRV 1024 X 768 4 colors
OAK10241.DRV 1024 X 768 16 colors
OAK76816.DRV 768 X 1024 16 colors11. LOTUS V3.0 & V3.1
INSTALL.DDF
L800VGAS.DLD 800 X 600 16 colors
VGA831CC.VBD 100 X 31 TEXT
VGA843CC.VBD 100 X 43 TEXT
VGA875CC.VBD 100 X 75 TEXT
L104VGAS.DLD 1024 X 768 4 colors
VGA140MM.VBD 128 X 40 TEXT
VGA154MM.VBD 128 X 54 TEXT
VGA196MM.VBD 128 X 96 TEXT
L116VGAS.DLD 1024 X 768 16 colors
VGA140CC.VBD 128 X 40 TEXT
VGA154CC.VBD 128 X 54 TEXT
VGA196CC.VBD 128 X 96 TEXT
L716VGAS.DLD 768 X 1024 16 colors
VGA727CC.VBD 96 X 127 TEXT
VGA753CC.VBD 96 X 53 TEXT
VGA773CC.VBD 96 X 73 TEXT12. ORCAD V4.0
OAK1K.DRV 1024 X 768 16 colors
13. P-CAD V4.5
VGA800.DRV 800 X 600 16 colors
VGA1024.DRV 1024 X 768 16 colors
VGA768.DRV 768 X 1024 16 colors14. PRESENTATION MANAGER 1.1
O67_800.DLL 800 X 600 16 colors
067PM1K.DLL 1024 X 768 16 colors15. UTIILITY
READ.ME Read this file for more details.
VGAMODE.EXE V1.14 allows you to select different modes and
turn on the backward emulation.
RAMBIOS.COM V1.00 loads the VGA BIOS into available system RAM.
LOADFONT.EXE These files are used to load a different font or
EDITFONT.EXE edit a font.
FONT.TAB
8X8.FNT
8X14.FNT
8X16.FNT
VESAPARM.COM Enables VESA High-Refresh monitor timing. This is
used in conjunction with the VESA jumper selection.16. VENTURA V2.0
VP20.EXE Installation file for VENTURA
VP2_0.TXT Text file required by the Installation file
VOAK800.VGA 800 X 600 16 colors (also works with Ventura 1.1)
V16C768.VGA 768 X 1024 16 colors
V4C1024.VGA 1024 X 768 4 colors
VOAK1024.VGA 1024 X 768 16 colors17. VERSACAD 6.0 & VERSACAD/386 6.0
OAK.CFG Configuration file for VersaCAD 6.0
OAKP.CFG Configuration file for VersaCAD/386 6.0
OAK.EXE 4 and 16 color driver for VersaCAD 6.0
OAKP.EXE 4 and 16 color driver for VersaCAD/386 6.0
OAK256.EXE 256 color driver for VersaCAD 6.0
OAK256P.EXE 256 color driver for VersaCAD/386 6.0
FREEDRVR.EXE Unloads TSR driver from memory
VCAD1.BAT VersaCAD 6.0 16 color
VCAD2.BAT VersaCAD 6.0 256 color
VCAD3.BAT VersaCAD/386 6.0 16 color
VCAD4.BAT VersaCAD/386 6.0 256 color18. VESA TSR
OTIVESA.COM VESA TSR for Oak OTI-067 and OTI-077 VGA controllers.
19. WINDOWS 286 V2.11
VGA800.DRV
VGA800.GRB 800 X 600 16 colors
VGA800.LGOO4C10242.DRV
O4C10242.GRB 1024 X 768 4 colors
O4C10242.LGOOAK10242.DRV
OAK10242.GRB 1024 X 768 16 colors
OAK10242.LGO20. WINDOWS 386 V2.11
OAK80016.DRV 800 X 600 16 colors.
OAK80016.GRB
OAK80016.LGO
OAK80016.386
OAK80016.3EXOAK10243.DRV 1024 X 768 16 colors.
OAK10243.GRB
OAK10243.LGO
OAK10243.386
OAK10243.3EXO4C10243.DRV 1024 X 768 4 colors.
O4C10243.GRB
O4C10243.LGO
O4C10243.386
O4C10243.3EX21. WINDOWS 3.0
VDDOKVGA.386
SETUP.INF
VGA768NL.DRV 768 X 1024 16 colors (8 bit slot)
VGA768L.DRV 768 X 1024 16 colors (16 bit slot)
VGA1KNL.DRV 1024 X 768 16 colors (8 bit slot)
VGA1KL.DRV 1024 X 768 16 colors (16 bit slot)
VGA1280L.DRV 1280 X 1024 16 colors (16 bit slot)
OAK8640L.DRV 640 X 480 256 colors (286 or better)
OAK8801.DRV 800 X 600 256 colors (all machines)
OAK81KL.DRV 1024 X 768 256 colors (286 or better)22. WINDOWS 3.1
VDDOKVGA.386
OEMOAK.512
OEMOAK.350
OAK81KL.DRV 1024 X 768 256 colors (286 or better)23. WINDOWS 3.0/3.1 32k & 64k
OEM32k.512
OEM32k.350
OTA6448H DRV 640 X 480 32K colors
OTA6440H DRV 640 X 400 32K colors
OEM64k.512
OEM64k.350
OTA6448X DRV 640 X 480 64K colors
OTA6440X DRV 640 X 400 64K colors
OTAVDD 386
OTAVGA GR3
VGACOLOR GR224. WORDPERFECT V5.0
OAK.WPD 800 X 600 16 colors
25. WORDPERFECT V5.1
OTI800.VRS 800 X 600 16 colors
OTI1024.VRS 1024 X 768 16 or 4 colors
OTI76816.VRS 768 X 1024 16 colors
OTITEXT.VRS 132X60 or 132X25 or 132X43 TEXT RESOLUTION
Hm. What do you think ? Maybe the content is useful to anyone ?
Personally, I think it might. But Elianda's version is more important, because it is more complete.
That 8514/A program is missing in my dump of the diskette, most notably.
Last but not least, this version requires a more recent VGA BIOS (-v1.05-) to be installed on the cards, maybe.
Best regards,
Jo22
