Daggerfall problems
First post, by Dogar
I've been having trouble with my Daggerfall installation. First of all, I've managed to get the install working in Dosbox, but for some reason it says that all my drives only have 105 megs of space, meaning I can only install the minimum version. Also, when I've finished the minimum installation and go to the game directory to play it, it says the wrong cd is in the drive. When I try and run it from the cd, it says that I must install the game first. 😒
I haven't made any changes to my compp since I first put the cd into the drive. All I've done is mounted my C drive and mounted my cd player with "mount g "G:\" -t cdrom -usecd 0 -ioctl"
I'm running a Pentium 4 processor under Win XP, if anyone could help I'd greatly appreciate it. 😀
Reply 1 of 2, by eL_PuSHeR
RTFM!
There are some options to specify disk size when mounting volumes.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 2, by DosFreak
Mount CD
Also run daggerfall with FALL.EXE z.cfg otherwise Daggerfall won't use z.cfg
If you wish to run Daggerfall without the CD then simply copy the CD to another directory and then point to that directory in z.cfg. Remember to run Daggerfall with "Fall.exe z.cfg"
Make your games work offline
