First post, by haker120
I finally got it, I managed to run some games in glide at 1024x768 in 32bit color mode but Quake 2 keeps kicking me to software renderer unless I'll choose lower resolutions. Any way to run Q2 in glide at this resolution?
Reply 1 of 13, by TrashPanda
Quake 2 doesn't use Glide, it uses OpenGL via the 3DFX MiniGL driver, as such as long as your desktop is in 32bit color mode Quake2 will use that, just make sure the MiniGL DLL file is in your quake2 directory.
Reply 2 of 13, by haker120
Ok but what file?
Reply 3 of 13, by TrashPanda
haker120 wrote on 2023-05-10, 11:04:
Ok but what file?
http://falconfly.3dfx.pl/minigl.htm
Use the MiniGL 1.47 version from that site for the best all round compatibility and speed, unzip and copy the 3dfxgl.dll file from the Quake2 directory into your Quake2 directory, the ZIP also contains the DLL for other Quake based games.
Reply 4 of 13, by haker120
Thanks a lot @TrashPanda, finally V5 on maximum usage. 😁 However, I saw Rayman 2 GOG version forces 32bit color and I cannot do this on real machine. Am I doing something wrong or it's possible only via emulation?
Reply 5 of 13, by TrashPanda
haker120 wrote on 2023-05-10, 11:15:
Cant help you with the GOG version, its best to ask on the GOG forums as they likely tweaked stuff to get it working, its possible they can point you in the right direction for getting the OG version to do the same.
Reply 6 of 13, by haker120
Well, I copied whole package from GoG (I bought that one), removed all glide emu files and welp, kicks back to 16bit color palette so I guess I'm out of luck for this one. 😁
Reply 7 of 13, by Truffon
Hi,
You should check pcgamingwiki, there is a section "issues fixed" in which they talk about the 32bits rendering issue on glide and what tweaks needs to be done. (I guess you can skip the nglide part, as you have a 3dfx card)
Reply 8 of 13, by haker120
Unfortunately replacing that dll and changing from 16 to 32 kicks back to 640x480 in software rendering.
Reply 9 of 13, by leileilol
Use default OpenGL. 3dfx OpenGL there's for Glide 2x which doesn't know what 32-bit rendering is nor what high resolutions are, generally how 3dfx hardware rolled in Dec 1997.
long live PCem
Reply 10 of 13, by haker120
But there is a patch that works with nglide, I asked at raymanpc.com and the person who made patch will hopefully help me. 😉
Also Rayman 2 supports only real glide or DirectX and choosing DX is really a poor choice. 😁
Reply 11 of 13, by Dolenc
You can set 32bit rendering for glide applications in 3dfx control panel. Rendering depth or smthing like that is the property name.
Reply 12 of 13, by haker120
I need to check that, thanks @Dolenc. 😀
Reply 13 of 13, by haker120
Forcing 32bpp makes games to dectect smaller resolution, Rayman 2 in 800x600 max and honestly I'm not sure that works, I think will be better to stay at default 16bpp in 1024x768, this card is more like collectors item to use from time to time, not like daily use. GF4 or Radeon 9600 are more like for daily use. 😁
