First post, by dreamblaster
Hi,
I am making a sturdy ready to use MDA, CGA, EGA and Hercules to HDMI converter.
It will be available here : https://www.serdashop.com/MCE2HDMI
and it is software compatible with Hoglets RGB2toHDMI software (https://github.com/hoglet67/RGBtoHDMI).
My version uses a pi3A+, and everything is integrated in a high quality enclosure.
EDIT : Review by Retro Erik : https://youtu.be/jDC7cryO6Fo?si=QJT_WE-VDh0K6vdm
I was previously working on a new video converter with FGPA, and a video converter with CM4 module,
(See below original MCE2VGA and CM4 version of MCE2HDMI)
but both these are still hard to source.
Now it seems PI3A+ was available again, i bought some of these and redesigned to this form factor.
Meanwhile i also made it compatible with RGBtoHDMI , as I think this is the best software option for the project.
I hope you like it !
New X2GS TE & X16GS sound card : https://www.serdashop.com/X2GS-TE ,
Thanks for your support !
