First post, by thequad
Hi everybody,
Well... I'm a long time user of Glidos, but this time I can't get it to work properly ... 😢 I've just installed GLIDOS 1.32 (registered) + VDMSound and I 've also installed both TR1 (by using TRinstaller) and TRUB.
It's a new installation since I've changed my MB and CPU recently.
TRUB works fine (1600*1200, with sound) when TR1 does not.
The game launches (with sound) and stops immediatley after the CORE logo.
Here is the log from Glidos:
Démarrage du Serveur Glide v1.32 (c) Paul Gardiner 2001-2004,
version française par TRO http://www.tro-online.com
VESA mode 0x101
VESA mode 0x101
VESA mode 0x110
Resolution = 640x480
Refresh rate = 60Hz
Color format = ARGB
Number of color buffers = 2
Number of aux buffers = 1
VESA cmd 4F07, 0, 0, 0
GlideShutdown
It's always the same... all settings for my ATI driver are set to default .
Any idea?
MB : ASUS P4U800-X Socket 478
CPU: Celeron D 330 2.66
SDRAM: 512 Mb PC3200
GRAPHIC: (ASUS) ATI 9200SE 64Mb
OS: WinXP sp2
Reply 1 of 3, by Glidos
TR and UB can get very confused if you have both CDs in drives symultaneously
Reply 2 of 3, by thequad
funny enough ...but that's the solution ... 😊
thanx a lot 😁
TheQUAD
Reply 3 of 3, by Glidos
Don't worry. Easy trap to fall into, and one that Glidos doesn't check for (unlike the empty drive problem).
