First post, by gaffa2002
- Member
Hello once again,
From time to time I try running this game with sound, CD audio and smooth framerate, but I was never able to get it running 100%, and that includes attempting with period correct hardware. I always blammed the system I was running it, so my last attempt was using PCEM and trying different CPU speed and video card combinations, but I always ended up having the same issues I get on real hardware regardless of configuration:
-If I run the game in a window, movement is not smooth and game speed is correct.
-If I run the game full screen (FAST) without the sync with monitor checked, game speed is correct, but lots of screen tearing and jerky movement
-If I run the game full screen (FAST) with the sync with monitor checked, game is smooth, but runs a bit faster at 70fps (as it uses 320x200@70hz for this mode). This was what I used back in the day and never knew I was playing the game faster than it was supposed to be, not to mention the sound seems to get a bit out of sync as the animations run a bit faster.
-If I run the game full screen (SMOOTH) without the sync with monitor checked, game runs at normal speed, but lots of screen tearing and some artifacts when the screen is scrolling (looks like some vertical stripes on screen). This gets better/worse by using slower/faster CPUs or slower video cards, but never gets solved.
-If I run the game full screen (SMOOTH) with the sync with monitor checked, game runs extremely fast even on a 486! The artifacts during scrolling get even worse in that mode, too.
I already tried many different system combinations in PCEM, plus real hardware (Athlon 750 + Geforce MX440, a Pentium 200 + Virge S3, and I clearly remember having the same problems on my Pentium 100 + Ati Rage II back in the day). It just...doesn't...work! I always have the same issues regardless of machine.
Did anyone ever run this game using the full screen (SMOOTH) mode (320x240@60hz) with sync to monitor enabled and it worked as intended by running at 60fps?
LO-RES, HI-FUN
