First post, by mrguyisme
Hi, I'm new here and I don't know the first about programing 😀. Before I posted this I did a search on magic carpet and I couldn't find any posts that address this particular issue.
Okay the problem I'm having with magic carpet is that I can't get it to run passed the language and sound setup screen. After I pick everything the screen turns black and it stays that way. I am able to run the game without dosbox but its runs ridiculously fast I heard you could use dosbox to emulate the game and gain some control over the speed so I figured with this program I'd be able to slow the game down. I am able to play kings quest 6 with dosbox just fine but magic carpet doesn't run passed the setup screen. Also if I try to run hidden worlds it crashs as soon as I select the game I want to play.
My computer specs are as follows:
1.3ghz p4
384Rambus
geforce fx 5200 128ram
Any help would be most appreciated.
