First post, by keenmaster486
Yes, I know of projects such as the Lo-Tech 1MB RAM board. But what about solutions involving old cards?
I have an AST SixPakPlus, which has 384K currently installed. The documentation says it can go up to 576K, though... how? It's completely populated.
Here's what I currently have:
Onboard RAM: 64K
AST SixPakPlus: 384K
AST RamPage: 256K
Total: 704K
However, I'd like to try to get more RAM with a single card. The SixPakPlus is nice because it has I/O ports on it, saving a slot for other things.
With the 5 slots in the 5150, I'd like to end up with:
1. Graphics
2. RAM
3. FDD/HDD controller
4. Network card
5. Adlib or Sound Blaster 1.0/2.0
And the I/O integrated into either the RAM card or the FDD/HDD controller.
Interested to hear what solutions others have come up with.
World's foremost 486 enjoyer.
Reply 1 of 5, by Jo22
Technically, ISA bus or PC bus cards can be stacked, I believe, since ISA slots are wired in parallel..
- Except that special purpose slot #8 (?) on the 5150. It was intended for a fast serial port or something.
On ISA cards, there are sometimes solder joints in parallel to the edge connectors.
By installing a pin header, it would be possible to "sandwich" two of them together.
Speaking under correction, however.
    280.94 KiB
    Source : https://retrocmp.de/hardware/rampage-at/ast-rampage-at.htm
Reply 3 of 5, by waterbeesje
For the stacking, you may like to read about the Ibm 5151 unit, it acts exactly that way 😀
As for the ram expansion, I have a ram card that takes 4 banks of ram, either 64kbit or 256kbit chips, and a dip that sets the starting offset. That maxes out any 51x0 8088 and clones. I still want to use it one day to max out my own Multitech MPF+PC clone thing once, as soon as I get it to work properly.
Stuck at 10MHz...
Reply 4 of 5, by Jo22
keenmaster486 wrote on 2023-05-25, 04:16:
Well, I think I want to stay away from modifying my old cards.
Oh, okay. I do that all the time. 🤷‍♂️
    219.54 KiB
    Hercules clone card w/ extension
Reply 5 of 5, by maxtherabbit
keenmaster486 wrote on 2023-05-24, 15:57:
Yes, I know of projects such as the Lo-Tech 1MB RAM board. But what about solutions involving old cards? […]
Onboard RAM: 64K
AST RamPage: 256K
Total: 704K
1. Graphics
2. RAM
4. Network card
What about ditching the six pack and just adding more memory to the rampage? Doesn't it support up to 1MB?
