First post, by HanSolo
Recently I bought three Ipox IP-3ETI23 mainboards (S370) with P3-933 CPU. According to the seller all were once taken out of running systems, so I hoped they would all just simply work.
When I first powered them on, all three greeted me with the same beeps: three long and then a alarming constant high/low sirene (with the long beeps still in background)
A simple CMOS-Reset cured two of the boards, but the third is still in a somewhat half-broken state: After the CPU identification it simply stops. The CPU itself works in one of the other boards and another CPU gives the same result.
I also tried: swapping the battery, no keyboard, other RAM, other RAM slot, other CPU-fan connector
Any ideas anybody?
BTW. I can reproduce the long beep + sirene-alarm by removing the RAM stick which i find strange. The long beeps are the missing memory, but why is this also causing the sirene?
Reply 2 of 3, by HanSolo
Ok, I'd try that. But honestly I have no experience with that and not the right tool. Are those chips fragile or can I do that with a thin screwdriver?
Reply 3 of 3, by bogdanpaulb
Best way, for me, if you don't have a tool like this https://www.aliexpress.com/item/32812134008.html, is to use a wear down https://www.amazon.com/Tweezees-Professional- … y/dp/B00PVWRLO0 that is 'adapted' to fit the 'extraction' holes. But other the that, you can use anything that fits, as long as you are careful and don't apply to much force.
    209.26 KiB
